Hi there!
I’m having issues currently that I didn’t have before with Supervisor or with addons. Whenever I go on my server from an external network on the Supervisor page or on a addon ingress page that I pinned on the side, it takes a lot of itme to load.
When I do the same but from the internal network, no issues. I don’t see any logs with issues.
Here is my setup:
- RPI4 4GB RAM (using good power adapter)
- 128Gb SANDISK usb hard drive (boot on usb)
- Ubuntu 20.04 server LTS
- Using docker image (followed Installing Home Assistant Supervised on Raspberry Pi OS)
- Using duckdns + nginx
- Conbee 2 attached
- Addons: ADB, duckdns, file editor, grafana (disabled), home assistant google drive backup, influxdb (disabled), mariadb, mosquitto broker, nginx, zibee2mqtt edge
For info, the memory usage is about 26%, 13.6% of hard drive used, 35°C. In terms of internet connectivity, using Google DNS in my router, using IPV4 (I can"t seem to use V6 since I’m using a router behind the internet supplier router and passtrough just doesn’t work).
My download is 18.32Mb/s, upload 0.804Mb/s (using nPerf). When using my internet supplier status I’m at 20.7 and 1.1.
I tried to flash everything back from scratch but to no avail. I tried reinstalling every addon but doesn’t do anything either.
I really don’t know what to do, I hope I don’t need to use a NUC instead since the only issue is when I’m outside of the home network… Furthermore it’s only the supervisor, lovelace works fine, I can’t easily move between the menus et go into the HA config.
Using app on android or through chrome is the same (same on Windows using my phone connection).
Thanks for your help!
