Supervisor timeout on call (API) and global system freeze
Hi, I’ve been trying to understand what happened to my HA instance for days without a solution, despite having read hundreds of posts around the web.
For some issues, I decided to create a new HA instance but I have the same problem
I go straight to the point, because after a series of tests, I realized that everything comes from the Supervisor and these are some errors that appear (at least once or twice in an hour) with a freeze of the system for a few minutes and sometimes (not always) can also lead to an automatic reboot.
The issues starts when I launch Node-red that use mosquitto broker to discover the entities of my alarm panel
Supervisor:
24-02-18 20:00:06 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-18 20:00:07 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-18 20:00:07 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-18 20:00:08 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-18 20:00:09 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-18 20:02:25 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from core_mosquitto
24-02-18 20:02:26 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 20:02:27 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
24-02-18 20:02:27 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 20:02:28 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 20:02:44 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
24-02-18 20:02:44 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
24-02-18 20:02:44 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
Core:
2024-02-18 20:02:38.404 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547237622336] Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2024.01.1 aiohttp/3.9.3 Python/3.12): Unexpected error inside websocket API
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 385, in async_handle
msg = await wsock.receive()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 486, in receive
await self.pong(msg.data)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 328, in pong
await self._writer.pong(message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 709, in pong
await self._send_frame(message, WSMsgType.PONG)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 682, in _send_frame
self._write(header + message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 702, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2024-02-18 20:02:39.402 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 715, in ping
await self._send_frame(message, WSMsgType.PING)
2024-02-18 20:02:39.440 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
Supervisor:
24-02-18 18:50:32 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
24-02-18 18:51:02 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-18 19:06:04 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
24-02-18 19:06:04 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 19:06:05 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
24-02-18 19:06:05 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 19:06:37 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:06:42 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:07:28 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:07:29 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:07:32 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
24-02-18 19:07:36 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
24-02-18 19:07:37 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
24-02-18 19:07:37 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
24-02-18 19:07:38 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
24-02-18 19:21:08 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-18 19:28:21 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:28:29 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
24-02-18 19:28:30 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 19:28:50 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
24-02-18 19:28:50 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
24-02-18 19:28:50 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
24-02-18 19:46:39 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:46:48 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
24-02-18 19:46:48 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
24-02-18 19:47:44 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:47:45 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:48:20 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-18 19:48:29 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
24-02-18 19:48:30 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
Core:
2024-02-18 19:29:41.691 ERROR (MainThread) [custom_components.tapo_control] HTTPSConnectionPool(host='192.168.1.113', port=443): Max retries exceeded with url: /stok=453c37d512095564d7903c214d0e3661/ds (Caused by SSLError(SSLError(1, '[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1000)')))
2024-02-18 19:48:25.700 ERROR (Thread-12 (_thread_main)) [paho.mqtt.client] failed to receive on socket: [Errno 32] Broken pipe
2024-02-18 19:48:25.810 WARNING (Thread-12 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server 192.168.1.49:1883 (7)
2024-02-18 19:48:26.996 ERROR (MainThread) [custom_components.tapo_control] ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2024-02-18 19:48:27.128 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547244313024] Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2024.01.1 aiohttp/3.9.3 Python/3.12): Unexpected error inside websocket API
2024-02-18 19:48:27.454 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547244316864] Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2024.01.1 aiohttp/3.9.3 Python/3.12): Unexpected error inside websocket API
2024-02-18 19:48:27.722 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-02-18 19:48:27.831 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
I tried to downgrade the Core (from 2024.2.2 to 2023.12.0), because I didn’t have these issues in November and December, but I didn’t solve it.
My current versions are:
Core 2023.12.0
<Supervisor 2024.01.1
Operating System 11.5
Similar issue
Similar issue after latest update. Restarted and system just hangs and logs show Timeout on call errors. Restored to previous backup and things are fine. Not sure what the underlying issue is.
so frustrating. SOMETHING has changed. I keep updating to the latest version hoping it will resolve my restart issue but it doesn’t.
Did you find the root cause? I’m having similar issues with the 2024.5 installation on a raspberry pi 4.
I am having the same issue! :frowning:
The same error here
The system also hangs, lots of reading of disk and higher CPU usage.
I just recently started seeing this same issue of random freezing. It started after I upgraded zwavejs to 3.7.1 but downgraded to 3.6.0 and still see the issue. I had been running 2024.5.1 without any issues and tried updating to 2024.6.0 to see if it would help. So far nothing has helped.
Update: well not certain yet what caused this for me but i restored a backup from 5/30 (automatic backups every other day) and no lock ups. Glad to see my backups worked and to be able to have it working again.
I fixed it by replacing my Rpi4 with an Intel Mini Pc and a backup of my HaOS instance. No more freeze or error in supervisor logs.
