I’m being offered the update from supervisor 6.8 to 8.1, but if I click on it, it sits there spinning the blue circle over the update for a few minutes and then pops up this box:
Set-up is a Raspberry Pi4 running core-2021.8.8 under Home Assistant OS.
Aside from this error everything seems to be running correctly, and there’s nothing unusual in the log except this:
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:109
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 8:50:28 AM (1 occurrences)
Last logged: 8:50:28 AM
Failed to to call /supervisor/update - Update of Supervisor failed: Can't install ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2021.08.1&fromImage=ghcr.io%2Fhome-assistant%2Farmv7-hassio-supervisor: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
which mirrors what’s on the pop-up. Is this just an issue with the remote server being unavailable, or something wrong at the local end?
I’ve always had to do it via the notifications in the supervisor dashboard, same as for Core etc… And it’s offering me the update that way as normal, see the background of the image on the first post.
It’s always worked flawlessly up to now for updating. Just this problem which started last night and is still ongoing. I’m still wondering if it’s an issue at the remote server end (or a DNS issue perhaps), given it’s a time-out etc.
~ $ ha dns info
host: 172.30.32.3
locals:
- dns://8.8.8.8
- dns://1.1.1.1
- dns://192.168.0.210
servers:
- dns://192.168.0.200
update_available: false
version: 2021.06.0
version_latest: 2021.06.0
192.168.0.210 is my pihole server, and i just added the server 0.200 (my router) plus the other two to give options and did a restart. Still the same error immediately…
And if I ping ghcr.io it seems to be resolving and working:
~ $ ping ghcr.io
PING ghcr.io (140.82.121.33): 56 data bytes
64 bytes from 140.82.121.33: seq=0 ttl=55 time=19.168 ms
64 bytes from 140.82.121.33: seq=1 ttl=55 time=17.859 ms
64 bytes from 140.82.121.33: seq=2 ttl=55 time=18.202 ms
64 bytes from 140.82.121.33: seq=3 ttl=55 time=17.752 ms
64 bytes from 140.82.121.33: seq=4 ttl=55 time=18.668 ms
^C
--- ghcr.io ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 17.752/18.329/19.168 ms
~ $ ha supervisor update --version 2021.8.1
Processing... Done.
Error: Update of Supervisor failed: Can't install ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1: 500 Server Error for http+docker://localhost/v1.41/images/createtag=2021.08.1&fromImage=ghcr.io%2Fhome-assistant%2Farmv7-hassio-supervisor: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: no such host")
If I add the DNS entry specifically into PiHole as a local address, it ends up with a 404 error instead
Processing... Done.
Error: Update of Supervisor failed: Can't install ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1/json: Not Found ("no such image: ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1: No such image: ghcr.io/home-assistant/armv7-hassio-supervisor:2021.08.1")
I was meaning more that the file does actually exist and I can access it from the server, although I had to remove a : from the end of what was in the error message for it to work.
That SSH looks a bit complicated - will look at it after dinner. I’m wondering though if a backup and reinstall might be an easier route.
Just tried it, and I can’t get it to work. The server (HASS Pi) refuses the key.
That’s with a NTFS formatted USB stick with keys made with Puttygen, and the file authorized_keys formatted as ANSI and unix LF using Notepad++ containing the public key (with the private key used with port 22222 in Putty to access).
