Supervisor Won't Start
I was about to show someone my Grafana graphs in HA when I started getting the ‘Unable to load the panel source: /api/hassio/app/entrypoint.js’ error. In researching, this appears to be related to hassio-supervisor not running. I am able to SSH into my HA server and supervisor is not running. A restart will show it trying for 5 seconds over and over again until I stop it. I rebooted the whole server and none of my containers were started, presumably because supervisor can’t start. I was able to manually start a number of containers since I had the list of names in my SSH buffer.
I am seeing the following error in the logs:
20-03-03 17:23:58 INFO (MainThread) [__main__] Initialize Supervisor setup
  File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/src/supervisor/supervisor/__main__.py", line 41, in <module>
    coresys = loop.run_until_complete(bootstrap.initialize_coresys())
  File "uvloop/loop.pyx", line 1456, in uvloop.loop.Loop.run_until_complete
  File "/usr/src/supervisor/supervisor/bootstrap.py", line 61, in initialize_coresys
    coresys.hwmonitor = HwMonitor(coresys)
  File "/usr/src/supervisor/supervisor/hwmon.py", line 22, in __init__
    self.monitor = pyudev.Monitor.from_netlink(self.context)
  File "/usr/local/lib/python3.7/site-packages/pyudev/monitor.py", line 121, in from_netlink
    raise EnvironmentError('Could not create udev monitor')
OSError: Could not create udev monitor
20-03-03 17:23:58 ERROR (MainThread) [asyncio] Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0x7fe93974d410>
client_session: <aiohttp.client.ClientSession object at 0x7fe939778e10>
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Additionally, I cannot resolve anything on that box. The /etc/resolv.conf file is empty and is linked to a ‘…/run/…’ location. I assume that since supervisor is not running, that runtime location doesn’t exist.
It also appears that the age of the supervisor container is < 4 hours so did it do an auto update?
EDIT: @night provided a solution in Supervisor Won't Start
I have the exact same problem as you described and it happened after supervisor update 207 for me (https://github.com/home-assistant/supervisor/releases/tag/207)
Also found this closed ticket that seems relevant: https://github.com/home-assistant/supervisor/issues/1556
This supposedly fixes the problem (from the closed ticked I linked in the previous post), I’ll give it a try:
I am having the same problem. Running sudo -i and the install script did not help in my case.
Apologies to @frenck as I did the docker pull before reading his comment about not doing that (in the above referenced github ticket). I am working again now that I did the install. I did use the docker pull commands but not sure what actually caused it to start working, whether it was the install script or the docker pull. I also had an issue with DNS resolution that I had to fix before the box could resolve the update URLs.
I had to do this as well to fix it:
> docker pull homeassistant/amd64-hassio-supervisor:latest
> docker tag homeassistant/amd64-hassio-supervisor:latest homeassistant/amd64-hassio-supervisor:latest
Ref. https://github.com/home-assistant/supervisor/issues/1556#issuecomment-594075132
Thanks @night , that worked for me as well!
I hate those automatic supervisor updates. This is the second time it just killed my environment while not home!
I had the same problem this morning. Fixed it with running (as root) the install script as suggested here.
Same issue for me. Had some issues with the suggested fix. Ran both suggestions from @night. To run the curl command I originally ran it with ‘sudo’ but that didn’t work. Got an error ’ bash: line 133: /etc/hassio.json: Permission denied’ had to login as root and then run it. That worked and I’m back up and running. But, not sure whether it was just the curl command or the curl command and the docker commands were required to resolve the issue.
I typed sudo -i
then pasted the curl command and started again
Same thing here, had to reboot after the “docker” command.
Thank you all !
Yes, that’s what I had to do as well, I should have mentioned it. Here’s the the order I ran the commands in if anyone else still struggles with this.
sudo -i
apt-get update
apt-get install -y software-properties-common apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq network-manager socat
systemctl disable ModemManager
curl -fsSL get.docker.com | sh
curl -sL "https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh" | bash -s
Yeah, that’s not ideal. If you haven’t done it already I suggest you make a feature request to disable automatic updates here: https://community.home-assistant.io/c/feature-requests
It’s the first time I’ve had any issues, but if it’s after every supervisor release you should open a ticket about it to find the root cause.
Same issue here on ubuntu 18.04 since this morning.
Yesterday, HA showed the supervisor update in the Supervisor section, but I did NOT install it.
Apparently, it did not stop it from being installed automatically a couple of hours later…
This is not the first time these automatic updates broke stuff. The last time was the introduction of the DNS thing that broke internet connectivity for a lot of people.
Ugh, glad I found this thread, been pulling my hair out as to why things were suddenly having problems! The latter recommendations worked to resolve my problem. Not a fan of automatic updates, I’ve stopped unattended-upgrades in Ubuntu 18.04 because of that.
I’ve opened a request here: [supervisor] option for disabling auto-updates
Same here.
The solution from night worked for me.
Thinking about getting rid of hassio and managing core and addons myself through Docker/Portainer…
Thanks I added my vote to your thread.
Same issue here and can confirm solution from night got things going again. I’m also on Ubuntu.
