Same issue here on ubuntu 18.04 since this morning.
Yesterday, HA showed the supervisor update in the Supervisor section, but I did NOT install it.
Apparently, it did not stop it from being installed automatically a couple of hours later…
This is not the first time these automatic updates broke stuff. The last time was the introduction of the DNS thing that broke internet connectivity for a lot of people.
Ugh, glad I found this thread, been pulling my hair out as to why things were suddenly having problems! The latter recommendations worked to resolve my problem. Not a fan of automatic updates, I’ve stopped unattended-upgrades in Ubuntu 18.04 because of that.
Is there anyone who knows how to run the update if I can’t remember my Ubuntu username anymore? Or knows how to find my username on a headless Ubuntu 18.04. Running Hassio on headless Ubuntu server and nothing starts anymore but since I don’t know my username I am just stuck…
And somehow posting here gave me a brainwave. Remembered my login and with the help of this great community was able to fix the problem.
Updated and running again!
You need to describe the situation in more detail if we’re going to be able to help you.
What platform are you running on? Raspberry pi, Linux server (Ubuntu for instance).
What exactly did you try? Did you run the command on the host or inside a docker container? Try to recreate your steps and describe it here.
If I have installed Hassio in a RPI3+ and receives the following error:
Unable to load the panel source: /api/hassio/app/entrypoint.js.
I do not use docker, I simply took the image, used Balenaetcher and burned the image to the SD-card and updated Hassio and now I receive this error message. Im afraid that if I reboot my raspberry pi , it wont boot up in the GUI anymore. Any solution?
After this I had multiple errors showing that HA was unable to update stuff. This had to do with the dns needed updating. For this I followed these instructions.
