Support for KNX shutters (position/stop)
Full integration would be awesome. Just close or open them is working with a simple switch but it would be nice to stop and get status like position.
I would like to support test.
Looks like you would need some sort of 868 MHz transmitter working with home assistant to even consider getting this working
KNX isn’t based on wireless basically. A central shutter actuator knows the status/postion but HA isn’t able to query yet.
@svente08: I just added an attempt to support KNX shutters with a knx.cover component here if you’re still interested… :slight_smile:
That’s great. Looking into it upcoming week. Let you know. Thx :slight_smile:
Tested! It works perfect! Thanks!!
Not working perfect in my environment… Able to move the shutters but on HA dash the up button (down button when invert option is set to true) is greyed out. Seems that the current position is missing.
Dear tiktok7
Somehow I and at least someone else is having problems keeping the cover position correct… somehow the state update isn’t working for us…
See threat: [solved] KNX Cover - State updater not working (lights & switch do though)
