Hi, not sure it has to do with your code. Adding it manually worked fine! I’m happy to still make the issue if that helps you?
Some progress around the real-time updates. I have (test) version available that you can try, please be advised that there is still an annoying bug around the start-up time. Something blocks the HA start-up, which means that a full start-up can take up to 5 minutes.
You can download the zip below, extract it and put custom_components/nest_protect
in your custom_components
folder. If you have any feedback, feel free to create an issue.
https://github.com/iMicknl/ha-nest-protect/archive/refs/heads/enhancement/add_update_endpoint.zip
Real-time updates are now in version 0.2.0 of ha-nest-protect. Error handling and code quality are not yet at a point where I would like it, however due to time constraints this will take some time.
At least a working solution for now, hopefully.
@imick first of all, thank you so much for this plugin, I’ve been wanting to get this into HA for ages!
One thing that is confusing me slightly is that a “heat sensor” is exposed as part of the data. My understanding was that Nest Protect did not contain a heat sensor and therefore weren’t permitted in new builds in Wales, but obviously that data is coming from somewhere. Do you happen to know where?
If I can prove to the electricians and builders that the heat sensor is available, then I can continue to slot Nest Protect devices in around the house without issue, otherwise I’ll have to go to my current plan of using a different brand.
To be honest, no clue. It is just available in the data they expose. By the way, if you do an export of all data Google has on you, it will even list the values in Celsius. See Expose actual values (e.g. temperature / heat / light) · Issue #22 · iMicknl/ha-nest-protect · GitHub.
On the following page, they list a Heat sensor as well. 2nd gen Nest Protect sensors - Google Nest Help. Hope this helps.
Oh, fantastic, I spent months trying to track down that information and somehow completely missed that page!
Hi all,
I see this error in the logs:
2022-03-11 03:13:54 ERROR (MainThread) [custom_components.nest_protect] Subscriber: pynest exception.
File "/config/custom_components/nest_protect/pynest/client.py", line 225, in subscribe_for_data
result = await response.json()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1103, in json
raise ContentTypeError(
aiohttp.client_exceptions.ContentTypeError: 0, message='Attempt to decode JSON with unexpected mimetype: text/html', url=URL('https://czfe39-front01-iad01.transport.home.nest.com/v6/subscribe')
File "/config/custom_components/nest_protect/__init__.py", line 123, in _async_subscribe_for_data
result = await entry_data.client.subscribe_for_data(
File "/config/custom_components/nest_protect/pynest/client.py", line 229, in subscribe_for_data
raise PynestException(
custom_components.nest_protect.pynest.exceptions.PynestException: 504 error while subscribing - <html>
<head><title>504 Gateway Time-out</title></head>
<body bgcolor="white">
<center><h1>504 Gateway Time-out</h1></center>
<hr><center>nginx/1.10.3</center>
</body>
</html>
Thanks! Could you create an issue on GitHub? If this happens, you will need to reload the integration or restart Home Assistant for updates to come back in.
I restart my HA and the error logs are gone now…
This is mentioned in the release changelog; release v0.3.0 · iMicknl/ha-nest-protect (github.com). This will show up on GitHub or on HACS when you update. Always good to read this :-).
Just installed the Nest Protect integration, authorized my account, copied the token but after pasting it, it says “Unexpected Error”
Logs show “Invalid Grant”
2022-03-11 13:23:47 ERROR (MainThread) [custom_components.nest_protect] invalid_grant
File "/config/custom_components/nest_protect/config_flow.py", line 41, in async_step_user
refresh_token = await self.async_validate_input(user_input)
File "/config/custom_components/nest_protect/config_flow.py", line 26, in async_validate_input
refresh_token = await client.get_refresh_token(token)
File "/config/custom_components/nest_protect/pynest/client.py", line 89, in get_refresh_token
raise Exception(result["error"])
Exception: invalid_grant
Any idea?
Could you create an issue on GitHub? This will make it easier to have a look at your issue. The error handling still should be better though, that is on the todo list, however invalid grant I haven’t seen yet.
I assume you have a Google account? (and not a legacy Nest account).
I read but I couldn’t get the information about it.
Sorry for asking won’t do that again, specially when I received that awnser.
Feel free to ask again, I didn’t mean to be this blunt . Just wanted to point out that there is a changelog, in case you were not familiar with it. No hard feelings.
Thanks Mick!
That did the trick. I had the legacy account. After migration it seems to work fine!
DJ
Great to hear! In next update it will also reflect this better when the authentication is not correct. Good to understand that with a legacy Nest account, this experience can be confusing.
Really great to see the development here! I have been silently watching the updates. I have (3) Nest Protects that are around 5 years old - and still currently using the Legacy Nest API.
Looking forward to what appears to be added entities, based on what I see today on my Nest Protects with the legacy API.
Below is an example of one of my current Nest Protects.
Currently (almost) everything they expose in the API is also exposed in Home Assistant. In future version, I will disable some entities by default perhaps, if they are not used by many users.
See below screenshoto for the current state.
Great! Personally, I would like to have the ability to add all the entities. People can always choose to not display them in their lovelace entity listing.
Are the “Heat Test” and “Humidity Test” for the Nest Protects? Maybe the new models have extra items or my older one has sensors I didn’t realize existed.
I have been holding off upgrading HA for now (even though I could copy the old integration into custom components for now) since I would like to use your Nest Protect custom component once you feel it is ready.
I understand that once you migrate your devices from the legacy Nest Protect API to Google, you can’t go back - so just being cautious since all still works as is right now.
