When I scanned with NMAP I saw port 80 and 10000 appear for the NVR IP and when I used the vendor’s software as I said with port 10000 it worked there which is why I assumed it is the correct port.
Hello Again, from what i can see everything seems correct.
You can’t access the camera fede directly because they are in an NVR subnet.
For access using the NVR could you please sniff the eseecloud CMS on Windows using wireshark? (You should see the URL when the CMS start the stream of one camera)
P.S. Before the wireshark sniff could you try with this URL in go2rtc?
I will definitely try the wireshark sniff route. Never used before so a new thing to try.
Thank you so much for your fast responses so far. Really appreciate your kind help!
I had to reach out to OOSSXX, who made my NVR system to get the up to date firmware. Once you have it, you need to turn on the RTSP function in the firmware so you can access the streams with VLC.
You can pull up the main stream with rtsp://admin@(NVR IP Address):80/ch0_0.264 and the sub stream is rtsp://admin@(NVR IP Address):80/ch0_1.264. You just have to change the channel number for each camera, ch0=camera one, ch1=camera 2, etc.
My NVR looks totally different, but I have no doubt it’s the same guts. You may or may not have the RTSP option somewhere in the options already, but I know I didn’t with the stock firmware. You’d have to dig around in the menus.
may I ask what brand your NVR is? I have a YESKAMO NVR with a 2019 firmware as well.
My UI looks identical to the screenshot you posted minus the RTSP server option.
I didn’t send a query to YESKAMO customer support today hoping they will enlighten me but in the meanwhile thought to ask around.
The link that *.rom that you shared is that brand specific?
When you flashed the new firmware did you need to reconfigure the NVR? I.e. re-link the cameras etc?
Yeah. I have looked through them all. No such option for sure.
There is another comment claiming that he got the option after an fw update so I will ask that person the same question.
By the way hen you flashed the new firmware did you need to reconfigure the NVR? I.e. re-link the cameras etc?
Hi everyone. I’ve also been trying to connect my icatch DVR to home assistant for some time, but I’ve never found a solution. I created a topic about it some time ago (Help Need: Integrate icatch dvr into Home Assistant, Headers in FFMpeg Camera Platform). Now I came across this topic and I hope that I have found a solution. the problem is that I can’t find the url for a high quality video stream. I have analyzed a connection with wireshark when I use the native DVR app (socatch). you can find the results in my topic. I have never used wireshark but seeing the tcp flow I understood that there is a get request to the path “/cgi-bin/net_video.cgi?hq=0&iframe=65535&pframe=65535&audio=0”. below I found a “Magic” parameter which I believe is internal to the app. the dvr has 16 channels but it seems that the connection towards a single path (even changing cameras from the app, the request remains the same). I have tried to setup go2rtc in various ways (many described in the documentation) without having any success. Does anyone know how to help me?
