I did right after your last message. Now hoping they are as responsive and accommodating as in your case.
Thanks for the guidance!
Ilias
Ilias
Hi everyone. Iāve also been trying to connect my icatch DVR to home assistant for some time, but Iāve never found a solution. I created a topic about it some time ago (Help Need: Integrate icatch dvr into Home Assistant, Headers in FFMpeg Camera Platform). Now I came across this topic and I hope that I have found a solution. the problem is that I canāt find the url for a high quality video stream. I have analyzed a connection with wireshark when I use the native DVR app (socatch). you can find the results in my topic. I have never used wireshark but seeing the tcp flow I understood that there is a get request to the path ā/cgi-bin/net_video.cgi?hq=0&iframe=65535&pframe=65535&audio=0ā. below I found a āMagicā parameter which I believe is internal to the app. the dvr has 16 channels but it seems that the connection towards a single path (even changing cameras from the app, the request remains the same). I have tried to setup go2rtc in various ways (many described in the documentation) without having any success. Does anyone know how to help me?
Hello again,
as you suggested I contacted my NVR manufacturer and they sent me the following firmware:
FWHI36D_20211021_W-NVR_K8208-W_3_2_0_2_9013160200_RELEASE.rom
Can you confirm what firmware did you receive?
The reason I am asking is that I donāt see any option for RTSP server:
That screenshot is after the update to version 3.2.0.2
I will seek further support from the manufacturer but since they take a bit of time to reply I am exhausting my options.
In post 108 of this thread I saw this:
FWH136D_20210310_W-NVR_K8208-W_3_1_6_0_9013160200.rom
for comparison:
Kind regards,
Ilias
Hi Stefano,
just texting in case you missed my previous posts.
Desperate for help!
Kind regards,
Ilias
Hello @Ilias,
Unfortunately Iām trying to remeber but i cant⦠I have tried wireshark also with mine DVR and i canāt find the strings⦠but i remember that i have read somewhere the strings in some wireshark dumpā¦
Itās really strange that you have a different URL for streamingā¦
Iāll trying the last thing using and old windows version with Internet Explorer to check where i have seen the bubble string.
Best regards
Stefano
Thanks @Wes93
What model of NVR do you have? Is it K8208-W by any chance?
I have my nvr camera working with bobble protocol for a long time now suddenly it is not working anymore. I have upgaded to 1.7.1 but the addonn do not start at all and log only say :
13:06:15.438 INF go2rtc version 1.7.1 linux/arm64
13:06:15.440 INF [api] listen addr=0.0.0.0:1984
13:06:15.441 INF [rtsp] listen addr=0.0.0.0:8554
13:06:15.442 INF [webrtc] listen addr=0.0.0.0:8555/tcp
with or without yaml file log always show this addon do not start at all and log only show if i restart hassio and not when i restart the addon
In log viewver i have nothing but addon is red with āthe add-on is stoppedā
it is possible to use a previous release because 1.5 stopped working but it stars
my yaml
streams:
Salone: bubble://xxxxxx:80/bubble/live?ch=0&stream=0
GiardinoFronte: bubble://xxxxxx:80/bubble/live?ch=1&stream=0
GiardinoRetro: bubble://xxxxxx2:80/bubble/live?ch=2&stream=0
GiardinoLato: bubble://xxxxx:80/bubble/live?ch=3&stream=0
log:
level: info # default level
api: trace
exec: debug
ngrok: info
rtsp: warn
streams: error
webrtc: fatal
This is my NVR model N8216-2
Try to write to Alexx here:
Hi again,
just wanted to let you know that although I reached nowhere with bubble source, I got it resolved by firmware update.
Now I have RTSP server enabled on the NVR.
Thank you @Grauwulf!
I have it finally integrated with HA of course using the AlexxITs awesome go2rtc. Thank you @AlexxIT for the outstanding work!
Thank you @Wes93 for all your contributions.
Love the HA community!
If only the world was run by open source communities. It would have been paradise.
Perfect, iām happy that you have solved your problem
Iām glad you got it sorted!
Hello, thanks to the superb work of @AlexxIT I was able to install go2rtc and with the bubble command I receive the stream from my cameras.
How can I put this video stream on my HA dashboard?
Hi all,
I have a REIGY W-NVR K8210-3WS and Iām trying to find a proper way to set the cameras in frigate but so far without success.
I have frigate install on a NAS Docker and firgate integration on my HA.
Everything works fine but I cannot see the cameras of the above NVR in frgiate
Iām not sure what is the best way to try:
The current frigate config is:
go2rtc:
streams:
mjpeg_cam:
- "bubble://admin:[email protected]:80/bubble/live?ch=6&stream=0"
- "ffmpeg:mjpeg_cam#video=h264#hardware"
cameras:
parcheggio: # <------ Name the camera
ffmpeg:
inputs:
- path: bubble://admin:[email protected]:80/bubble/live?ch=6&stream=0 # <----- Update for your camera
input_args:
- -headers
- "Authorization: Basic YWRtaW46"
mjpeg_cam:
ffmpeg:
input_args: preset-rtsp-restream
inputs:
- path: rtsp://127.0.0.1:8554/mjpeg_cam
roles:
- detect
- record
parcheggio and mjpeg_cam are two config attempts for the same NVR camera but both fails
192.168.1.84:80 is the IP and Port of the NVR
Any help?
thanks
Hello again,
Iāve almost managed to configure my DVR, but I canāt get a video stream. When using go2rtc, it shows a āloadingā message, but nothing more.
I would like to provide more information that might be helpful. I have a DVR from the brand iCatch. To operate it, it uses a Chinese app called āiWatchDVRā for PC/Mac or āSoCatchā on the mobile version. Iāve tried contacting the manufacturer, but I havenāt received any response. Unfortunately, it seems that the connection is not through RTSP but through HTTP.
Iāve discovered that itās managed by a Hi3520 chip, which seems to be connectable through bubble source, but I havenāt been able to configure it.
By sniffing with Wireshark and connecting through the app, Iāve found that the app obtains the stream by connecting to this address:
http://192.168.1.92:9000/cgi-bin/net_video.cgi?hq=1&iframe=65535&pframe=65535&audio=65535
The complete request is:
GET /cgi-bin/net_video.cgi?hq=0&iframe=65535&pframe=65535&audio=0 HTTP/1.1
Host: 192.168.1.92:9000
Authorization: Basic ............
Magic: 406F8261-B1E0-4A7C-9888-6949F5APEC9F
HTTP/1.0 200 OK
Content-type: multipart/x-mixed-replace;boundary=--myboundary
--myboundary
Content-Type: application/octet-stream
I canāt understand what is this āMagicā parameter, does someone know what it is?
The strange thing is that the request doesnāt specify a specific channel, but it seems that the URL is always the same.
Furthermore, I canāt figure out the encoding used by the app.
Iāve connected to the URL through go2rtc, but as I mentioned earlier, I only see the āloadingā message.
Does anyone know how I can configure it? Iāve been trying to set it up for years, and go2rtc seems like the right road.
my config and some screenshot:
streams:
casameomartini: "http://admin:[email protected]:9000/cgi-bin/net_video.cgi?hq=1&iframe=65535&pframe=65535&audio=65535"
casameomartini2: "bubble://admin:[email protected]:9000/cgi-bin/net_video.cgi?hq=1&iframe=65535&pframe=65535&audio=65535"
casameomartini3: dvrip://admin:[email protected]:9000/cgi-bin/net_video.cgi?hq=1&iframe=65535&pframe=65535&audio=65535
casameomartini4: http://admin:[email protected]:9000/
In order for every stream:
Hi All, first thanks to anyone that studied and worked on it in last several years, im writing just to share my experience in order to keep trace and help the ones that have my same device (K9608-W).
First some data:
Device name: NVR
Device Model: K9608-W
HW Version: 2.1.0
SW Version: 2.7.14.20_22322230
Realdatetime: 12/08/2019 16:16
IP: 192.168.1.123
HTTP Port: 80
I have installed an instance of Home Assistant supervised on a debian virtual machine in VirtualBox by setting the network adapter as ābridgedā, and then i just installed the go2rtc plugin in Home Assistant by following instructions here GitHub - AlexxIT/go2rtc: Ultimate camera streaming application with support RTSP, RTMP, HTTP-FLV, WebRTC, MSE, HLS, MP4, MJPEG, HomeKit, FFmpeg, etc.
Then, once installed and added on left menu the go2rtc link, i clicked on it and on the top button āConfigā, then i wrote these lines to let it work (i think that is a very similar configuration used by someone else in this thread):
streams:
NVRCH1MainStream: bubble://admin:[email protected]:80/bubble/live?ch=0&stream=0
NVRCH2MainStream: bubble://admin:[email protected]:80/bubble/live?ch=1&stream=0
NVRCH3MainStream: bubble://admin:[email protected]:80/bubble/live?ch=2&stream=0
Save changes and click on Stream button on the Top of page; here select all the cams that you want to see by clicking on the checkbox and click on āstreamā grey button, if all goes good you should be able to see the streams.
Just few IMPORTANT notes:
-You have to use the correct credentials, if you dont have a password just use ā[ā¦] bubble://admin:@IP_ADDR [ā¦]ā
-You HAVE to use the web port (often 80 but check your network configuration) NOT the command or client port
-Channel numbers starts from 0 not from 1
-The stream 0 is the stream in high resolution but is little heavier while stream 1 is in low resolution but lighter
Hope this could help or be interessant for someone.
Thanks All
Hi @Ilias!
Can you provide step-by-step guide how to do that?
I have upgraded to 3.2.0.2 and enable RTSP server (Also there is options like Chromecast and Alexa)
(download fw from here)
http://helpen.dvr163.com/index.php/Wireless_NVR_Series_Upgrade_Package
but canāt uderstand what to do next. There is a lot of meassages in thread
photo_2024-03-25_14-57-57|666x500
from docker container
go2rtc | 23:44:01.798 INF go2rtc version 1.8.5 linux/arm64
go2rtc | 23:44:01.800 INF [rtsp] listen addr=:8554
go2rtc | 23:44:01.800 INF [api] listen addr=:1984
go2rtc | 23:44:01.801 INF [webrtc] listen addr=:8555
go2rtc | 23:48:21.195 INF go2rtc version 1.8.5 linux/arm64
go2rtc | 23:48:21.198 INF [api] listen addr=:1984
go2rtc | 23:48:21.198 INF [rtsp] listen addr=:8554
go2rtc | 23:48:21.199 INF [webrtc] listen addr=:8555
go2rtc | 23:48:34.929 ERR github.com/AlexxIT/go2rtc/internal/mjpeg/init.go:166 > error="streams: dial tcp XXXXX:80: i/o timeout"
streams:
NVRCH1MainStream: bubble://admin:pass@XXXXX:80/bubble/live?ch=0&stream=0
test: rtsp://admin:pass@XXXXX:80/ch0_0.264
btw rtsp://admin:pass@IP:80/ch0_0.264 from manual
Hello, have you figured it out? I have the same firmware installed (unit: K8210-3WS) and the above mentioned methods for showing the video stream of the nvr donāt seem to work for me.
Which firmware did you end up with? Do you have a link to it maybe? Best regarts.
