The Hue Smart Button only shows as a battery sensor, and is not available as a trigger device in automations like the Hue Dimmer Switch.
Is it possible to get them working like the dimmer switch? I’ve seen it might be possible to use the EventSensor CC but would be great to have this supported natively.
i am running the latest core version of home assistant but my hue smart button isn’t a switch device. Its only shown as a battery sensor. I use the button over the conbee 2 stick (deconz). Deconze has full support for the smart button.
I am really sorry, but I am very new, I was trying to get my hue button to work and came across this thread, I have now installed ssh, and HACS, but have no idea how I install the PR created by Clarkd, can anyone advice please.
You will only see battery, there is nothing wrong with that but in automations there will be new options for it. Just use device as the trigger and select your button or dimmer.
Hey folks, hopefully a basic question: I see in screenshots in this thread that the Hue Smart Button is appearing as part of the “Phillips Hue” integration. Does this mean I should be pairing it to the Hue Hub first? Or can/should the button be integrated in some other fashion? E.g. direct Zigbee connection from the HA box? The downside of pairing with the Hue Hub is that I have to choose a Hue light to control. Ideally I want to control other things with it and not a Hue light. Please let me know if there’s a more appropriate place to ask. Thanks!
I can only answer on the hue hub from what I’ve set up - but you can configure via the hue app so that pressing the button does not do anything (i.e. not associated with a light or a room/zone etc.) . it appears in the app but you can then set up an automation device trigger for pressing the button in HA.
Hi Josh. You can pair the Hue Smart Button with your Hue Bridge or Zigbee dongle. It will then appear as device in either the Hue or ZHA hassio integration. I have two buttons, one configured in each. I did this to compare the response speed because I was disappointed with response via the Hue integration.
Do you have a broken Hue light or one you no longer use? You can try to assign your button to that. Initially I created a fake room without any lights and assigned my button to that. But it seems the latest version of the Hue app doesn’t allow this anymore.
