Support for Xiaomi Vacuum X20+ to Xiaomi Miio integration
Hi, I just bought a Xiaomi Vacuum X20+ and it is detected from the Xiaomi Miio integration, but it says it is not supported.
The model id is xiaomi.vacuum.c102gl and it is supported in the Xiaomi Miot integration available in HACS, but I think it’s always better to have support with a core integration.
same here… Just tried to integrate my x20+ but got:
Same problem here.
same, is there any compatible option we can choose?
Same issue here with a xiaomi vacuum S20+
Check this out
or manually:
Does anybody know why the integration cant find my xiaomi x20+?
Hi, I have same issue with Xiaomi Robot Vacuum S20 EU. Device is recognised but model is not supported :frowning:
seems that you need to install the beta.
beta worked for me
i have this issue, do you find a solution?
install the beta!
already tryed this, but dont worked, its for X20, but my Vacuum is S20+
How to install specific integration beta version? Please :slight_smile:
wget -O - https://raw.githubusercontent.com/Tasshack/dreame-vacuum/dev/install | bash -
what server did you useit? Im on DE server and when i want to add dreame-vacuum, i get message that nothing is on that server. LE: sorry now i see is about X20, i have S20
could be closed…
I think i am EU / DE
S20 should be supported by the beta version: dreame-vacuum/docs/supported_devices.md at 272458bbe72d48bfac8262f08a432938d0abb14e · Tasshack/dreame-vacuum · GitHub
Buenas tengo una Xiaomi vacuum x20+ y conseguí agregarla y también a través de mapas conseguí limpiar en zonas y puntos específicos pero cuando intentó limpiar por habitaciones me dice que le faltan Keys y no sé cómo hacer
No sé cómo crear tampoco automatizaciones en las cuales me limpie una habitación en concreto
Alguien sabría como solventar esto
Muchas gracias de antemano
Hello, I have a Xiaomi x20+ vacuum cleaner and I managed to add it and also through maps I managed to clean in specific areas and points but when I tried to clean by room it tells me that it is missing Keys and I don’t know how to do it
I don’t know how to create automations in which it cleans a specific room
Does anyone know how to solve this?
Thank you very much in advance
