That’s sad to hear - and totally understandable at the same time.
I hope to see someone picking up this great project and bringing it back to HACS. Seems there are already more than 30 forks. So with a bit of luck someone steps up, hopefully by posting in this topic.
If you want, I forked the project and fixed almost all issues and pull requests in the original repo.
Feel free to test it and drop a on GitHub.
I’m waiting to be added to the official HACS “store”. It will be ready as soon as this pull request is merged.
I’ll try to continue developing it as much as I can, even if I don’t have much spare time.
And thank you very much @mayker for all your amazing work. It was easy to understand the code and modify it. If you’ll ever want to continue the development, just contact me.
mayker
(maykar (pronounced "maker" with a southern accent))
187
Awesome! Thanks so much for picking this up, I very much appreciate it and I’m sure many others will as well. Looks like it’s in good hands, nice work. I also must apologize for the spaghetti code.
There is one feature that I never got around to adding that may save you time in the future:
A config option for adding exception tagnames and classes. This way if anyone finds or creates another element that this interferes with, they can just add the exception themselves and not have to worry about it being added to the project right away or at all.
Not at the moment, I might consider it in case an home assistant update breaks things, or in case I find ways to have more free time.
I use kiosk mode myself, so I don’t rule out the possibility of maintaining it.
However, time is always scarce in life and for now kiosk mode is working decently for me. I decided to revive swipe navigation because there were some issues that needed to be addressed.
Hello everyone. In my case I have the dashboards configured in an unusual way. When I want to integrate these lines it says: “Integration error: swipe_nav - Integration ‘swipe_nav’ not found.”
When I check if the js is loaded I see that it is ok. I really don’t know if I’m doing something wrong.
I did the installation by hacs and add the js in configuration.yaml
Okay. But I don’t understand then if this does what I want. Would I have to put this code in all the yml? Because each dashboard that I have is in different files.
Working fine on brave browser on my mobile but cannot get it working on the Android companion app. Anyone encountered the same? Slowly working through the thread to see if I’ve missed anything.
I would love to use this as a swipe back from previous view and I use a lot of hidden views as well. Now we configure the swipe navigation on the whole dashboard but it would be great to be able to add them to the individual tabs so that one can for example decide that if I’m on tab “home” and swipe, do nothing. If I’m on the “Rooms” tab and swipe go to “home”.
Also custom:button-card seems to be a problem, anyway around that?
Old post
Edit: Okay I got it to work but not over a custom:button-card I would love to use this as a swipe back button like is the default on any other iOS app. But that kind of swap does open the HA sidebar menu. Can this be disabled somehow and can I configure the swap nav to somehow go to the previous page? (Even if they are hidden)
Old: I don’t get this to work on the iOS app, does it work with hidden tabs as well and do you configure for the whole dashboard or all the individual tabs?
I tried with the example in the docs right above my dashboards views:
Or might it be my custom:button-card breaking things?
I don’t think button-card is conflicting with the swipe but if you provide a minumum working example I can try to reproduce it.
About custom swipes, there is an open issue here which is under evaluation. However the request is about global custom swipes, not “per tab”. I don’t plan to add the per-tab custom swipe in the near future but you’re welcome to open a new issue and try to gather consensus from the community.
This behavior is the one described by the issue above (global swipe actions, e.g. go back on left-to-right swipe). It is under evaluation now, but it might find its way eventually.
