HA is not connecting to my Switchbot. It’s been working for well over a year.
Config:
rPi 4
HA version info:
core-2021.3.4
supervisor-2021.03.6
Home Assistant OS 5.12
Configuration.yaml hasn’t changed.
Any help much appreciated.
Logs: (MAC address masked)
2021-03-26 15:31:55 WARNING (SyncWorker_5) [switchbot] Cannot connect to Switchbot. Retrying (remaining: 1)...
2021-03-26 15:31:57 WARNING (SyncWorker_5) [switchbot] Error talking to Switchbot.
File "/usr/local/lib/python3.8/site-packages/switchbot/__init__.py", line 92, in _sendcommand
self._connect()
File "/usr/local/lib/python3.8/site-packages/switchbot/__init__.py", line 45, in _connect
self._device = bluepy.btle.Peripheral(self._mac,
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 391, in __init__
self._connect(deviceAddr, addrType, iface)
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 439, in _connect
raise BTLEDisconnectError("Failed to connect to peripheral %s, addr type: %s" % (addr, addrType), rsp)
bluepy.btle.BTLEDisconnectError: Failed to connect to peripheral E3:xx:xx:xx:xx:xx, addr type: random
I’m guessing that bluetooth drivers somehow got messed up in the latest OS release. Is there somewhere we can file a proper bug report so someone can investigate?
I’ve started noticing issues recently. I have 2 SwitchBot Curtains and using HACS’s SwitchBot Curtain. HA is throwing errors like this one:
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 350, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 558, in async_device_update
raise exc
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/switchbot-curtain/cover.py", line 164, in update
self._device.update()
File "/usr/local/lib/python3.8/site-packages/switchbot/__init__.py", line 189, in update
devices = bluepy.btle.Scanner().scan(scan_timeout)
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 854, in scan
self.stop()
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 803, in stop
self._mgmtCmd(self._cmd()+"end")
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 309, in _mgmtCmd
rsp = self._waitResp('mgmt')
File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 362, in _waitResp
raise BTLEDisconnectError("Device disconnected", resp)
bluepy.btle.BTLEDisconnectError: Device disconnected
Is your mac address lowercase in your configuration.yaml? Was having the same “Failed to connect” problem with a brand new switchbot, changed my mac address from uppercase to lowercase and it’s working now.
I have 2 Switchbot curtain pairs that ran flawlessly for a couple of months. Since updating to 2021.12 they are dropping out, getting unavailable a couple of hours after reboot.
I don’t see related errors in the log after they go unavailable. Also, sometimes one of the two in a pair goes unavailable, while the other is still there. Does someone have ideas on how to troubleshoot these kind of issues?
I just installed HA OS and using the official integration, it finds my SwitchBot curtain and gets the state and other details of the device but I just can’t control it. Still need to dig into logs but yea I cannot control it at all.
same for me! Can see everything of status of 2 curtains & 2 buttons, but can’t control them…
Can control them in the switchbot app or via Homey, but not via Home Assistant…
February’s release has for me has made integration with Google Home no longer work.
I can see the “curtain” switchbot devices in the Google Home app, but when I try to open them with a voice command Google responds with “I’m not sure what living room curtains you’d like to control”
While trying to add the Switch bot integration HASS says “Failed to connect”
It worked for a year or so but after upgrading to bullseye and 2022.3.3 it doesn’t work any more
