I have followed the steps above deleting the old zwave integration, removed the integration in configuration.yaml, deleted all zwave related files in /config and rebooted twice, but the Z-Wave JS integration won’t install.
From my old core.config_entries I have:
"usb_path": "/dev/ttyACM0"
"network_key": null
I am on
HASSOS: 5.12
HASS Core: 2021.3.3
If I leave the network_key blank or if I put “null”, I get the same error message: Failed to set Z-Wave JS configuration.
I have installed the addon through the Supervisor Official Addons, and it has started, but I can’t see it in integrations. No OZW log file yet.
When I try to add the integration now, I get “Failed to connect.”
Edit: After stopping the Z-Wave JS addon, the integration now shows both USBpath and a network_key, which I did not generate. It then stops with “Failed to start Z-Wave JS addon” and does not add the integration.
Yes, according to post above:
Sorry if I don’t follow, I was under the impression that my USB stick was at the same address as I used with zwave 1.4, i.e. /dev/ttyACM0. The ones available in the list are:
