At the moment I’m running Hassio on a Pi 3 B + with SD card and further a standard setup. I’m facing a lot of problems due to SD corruption. I installed Home Assistant with Docker on an Synology DS218+ this was no problem. But of course the Hass.IO is missing. In the Docker register you can find 3 Hassio supervisor add-ons. If I’m correct this will add Hassio to Home Assistant??
I have added:
homeassistant-aarch64-hassio-supervisor1
homeassistant-amd64-hassio-supervisor1
homeassistant-armhf-hassio-supervisor2
almost standard configuration. I only changed: automatic startup – volume all to the same /config folder – same network a Docker.
But the weird thing is none of the register add-ons will start….
error: exec user process caused "exec format error"
error: (MainThread) [hassio.bootstrap] Can’t find SUPERVISOR_SHARE in env!
error: standard_init_linux.go:189: exec user process caused "exec format error"
does anybody manage to get Hassio working without use off SSH?
Wills, thanks for the clear explanation!! I have 2 gb of RAM in my synology. I can select a maximum of 176 mb during the proces as mentioned above. can it be possible this is to less to run Hassio?
please see the error log.
Yea you don’t have enough RAM, you can easily add another 4GB or 8GB DDR3 SODIMM will cost you about £48 or equivalent currency for an 8GB Stick. Something like this here at Amazon Worth the upgrade!
Also ask a friend, they may have upgraded a laptop and have a spare 2GB or 4GB stick?
Ah i also thought there was a problem with the usb port. I finally found the setting but, i can not change it! Yust as by you there is a blue i it tells there could be compatibility issues between usb3.0 devices. Yeah but i needed it, as my Zwave stick is usb.
yes, i have also changed disk size from 10 to 30GB but finally after again installing VM with the Aeotec usb port i tried to start Home Assistant with
192.168.178.33:8123 or hassio.local:8123 now for 60 minutes i got only this:
finally after reinstalling and again 20 minutes i got Hassio working, now i got an extra serial port (usb) /dev/ttyACM0 but again, after giving /dev/ttyACM0. Now i got 1 everspring AN158 (i got 3 of them) so it should be working, but i can not go into the configuration menu of zwave. When i push config on zwave i got: there is already one instance of zwave (last item of the row). I only got the zwave menu earlier when zwave was not the last thing in the row!
I was able to get this up and running fine, but would like to load a snapshot from a previous hassio install. How do I access the file directory of the virtual drive in DSM?
