acl
(Adrian)
March 9, 2017, 1:22am
1
Synology 214Play anyone any idea how I can get netdisco to compile I seem to be missin missing
/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu-ccache-gcc
I extracted evansport-gcc463_glibc213_i686_patched-GPL.txz to /usr/share which I got from synology’s sourceforge site but it seems to be missing i686-pc-linux-gnu-ccache-gcc?
has anyone got this to work? I cannot unfortunately use docker images in the 214Play
I had the same issue on my Synology DS214play
I followed the procedure described here and it worked :
Yes, In the end I solved it following (loosely) the process outlined by molano here:
It involves installing Debian Chroot on the Synology, installing the dependencies there and then copying to the main DSM environment… Waaay beyond my technical paygrade, but it worked in the end…
One note… dependencies break again every time you upgrade HA to a new version, but at that point I was able to manually upgrade each one via pip directly from them DSM environment… something like
$ /volume1/@app…
