System_log: events are not fired despite "fire_event: true"
Hello everyone!
I’m setting up a SYSLOG server for my network ( guess I’m a little bit spoiled from work :wink: ) and I would like to have the HASS information also within syslog.
As far as I can see, there is no direct way to achieve this.
But I did stumble on the “system_log” feature, which can be used to fire events.
#** Ref: https://www.home-assistant.io/integrations/system_log/
system_log:
  fire_event: true
#** Log events to LOCAL (!) syslog
#** This does NOT send all messages from Logger to Syslog. It only allows you to
#** use notify.syslog2graylog to send messages like "push notifications" to syslog
notify:
  - name: syslog2graylog
    facility: local0
    platform: syslog
automation:
  - alias: Log errors to syslog
      platform: event
      event_type: system_log_event
#    condition:
      - service: notify.syslog2graylog
        # data_template:
        #   title: lalatitle
        #   #message: '{{ trigger.event.data.message }}'
        #   message: '{{ trigger.payload }}'
#        data_template:
          #message: '{{ trigger.event.data }}'
          message: "ss"
I played around a lot in order to get this work… hence all the lines with ‘#’.
I can get a message to syslog by using the Service notify.syslog2graylog from Lovelace. But it never gets fired from the automation.
What am I missing here? Any insights?
Thanks in advance!
Did you manage to solve it? I am having similar problems
Unfortunately not. I gave up on this as it seemed (at that time) that you could only send specific messages to syslog but not all above LEVEL.INFO for example.
I guess the only way right now would be to have syslog pick-up the homeassistant.log file itself.
