System Monitoring - How does yours look?
Ok. How do you backup your NAS?
I am doing this also via “Samba Backup”.
via Samba Backup
Hi! Can You share yaml code Home Assistant Info card?
Yes, no problem. I shared this a few posts back:
Learning so much today by using your stuff! Would you mind sharing the sensor config for the Home Assistant Info part too? I actually have managed to stumble my way this far… Just not sure how to get these missing items working…
For the File Size I use the build in integration
Below the sensor for the supervisor updates, more info can be found in this link:
  - platform: command_line
    command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"update_available":.data.update_available,"addons":[.data.addons[] | select(.update_available)]}'''
    value_template: "{{ value_json.addons | length }}"
    unit_of_measurement: pending update(s)
    json_attributes:
    - update_available
    - newest_version
    - current_version
    - addons
Oh and for the restart I simply call service: ‘homeassistant.restart’
Love this!
Wanting me to add more around Synology as mine is pretty plain.
Also, how are you monitoring MariaDB, PHP MyAdmin etc?
Hi @91JJ Those are the official add-ons, not separate containers or anything. But I have just followed some steps in another post in this forum: Get notified of Available Hassio Addon Updates
Then to show them in the dashboard I made a vertical stack inside a grid-layout for every addon like this:
    - type: vertical-stack
      view_layout:
        grid-column: 3/3
        grid-row: 1/1
      cards:
        - type: markdown
          content: >-
            <center><img src="/local/Pictures/addons/duckdns-ico.png"
            width="52"/> <center>DuckDNS</center>   <center>Installed: {{
            state_attr('sensor.duckdns', 'version') }}</center> <center>Newest:
            {{ state_attr('sensor.duckdns', 'version_latest') }}</center>
          style: |
            ha-card{
              background: none;
              box-shadow: none;
              font-size: 11px;
        - color: green
          decimal: '1'
          entity_row: true
          height: 12px
          name: CPU Temperature
          positions:
            icon: 'off'
            indicator: 'off'
            value: 'off'
          type: 'custom:bar-card'
          width: 50%
          tap_action:
            action: navigate
            navigation_path: >-
              https://bloomassistant.duckdns.org:8123/hassio/addon/core_duckdns/info
          min: 0
          max: 50
          severity:
            - color: '#ff4d4d'
              to: 50
            - color: '#00e64d'
              to: 100
          style: |
            ha-card {
              top: -10px;
              width: 80%;
              left: 10%;
          entities:
            - entity: sensor.duckdns_update_available
Hope this helps.
Any way to disable this behavior in canvas-gauge-card?
Every time my CPU speed refreshes the arrow starts from bottom and this annoys me a lot. :slight_smile:
cpu_gauge
type: custom:canvas-gauge-card
entity: sensor.cpu_speed
card_height: 200
gauge:
  type: radial-gauge
  title: Processor (%)
  width: 220
  height: 220
  borderShadowWidth: 0
  borderOuterWidth: 0
  borderMiddleWidth: 0
  borderInnerWidth: 0
  minValue: 0
  maxValue: 3
  startAngle: 30
  ticksAngle: 180
  valueBox: false
  majorTicks:
    - '1'
    - '2'
    - '3'
  minorTicks: 20
  strokeTicks: true
  highlights:
      to: 3
      color: rgba(200, 50, 50, .75)
  borders: false
Did you check the documentation? All Configuration Options
Tried it locally and “animation: false” solved that problem for me
I am mostly still trying to pull all the information I want to see into HA, but I have already managed to set up my Docker Monitoring Dashboard:
It is automatically showing all new docker containers(except for the Images, I have to store them on the server). Took me quite a while and I had to change the code of about 4 different HACS projects, but finally it is working as intended
You did that with some loop function?
I am using the auto-entities card(🔹 Auto-entities - Automatically fill cards with entities) to select the docker containers by name(with a wildcard)
A user has created a neat docker card if you’d like to revise your view:
@kamtschatka
Possible to share your source code for this card please?
thank you
I’m using PING in combination with the Uptime Card: https://smarthomepursuits.com/how-to-monitor-devices-in-home-assistant/
Sure:
type: custom:auto-entities
card:
  type: custom:easy-layout-card
  cards:
    type: custom:config-template-card
    variables:
      getEntityId: |
        entityid => {
          return entityid.replace("switch", "sensor");
    entities:
      - this.entity_id
    card:
      type: entities
      entities:
        - type: custom:fold-entity-row
          head:
            entity: this.entity_id
            type: custom:multiple-entity-row
            show_state: false
            image: >-
              "${'/local/logos/' +
              states['this.entity_id'].attributes.friendly_name + '-icon.png'}"
            entities:
              - entity: this.entity_id
                name: Off / On
                toggle: true
              - entity: ${getEntityId('this.entity_id') + '_status'}
                styles:
                  width: 200px
                  align: center
              - icon: mdi:memory
              - entity: ${getEntityId('this.entity_id') + '_cpu'}
                styles:
                  width: 90px
                  text-align: left
              - icon: mdi:memory
              - entity: ${getEntityId('this.entity_id') + '_memory'}
                styles:
                  width: 90px
                  text-align: left
              - icon: mdi:upload
              - entity: ${getEntityId('this.entity_id') + '_network_speed_up'}
                default: '-'
                styles:
                  width: 90px
                  text-align: left
              - icon: mdi:download
              - entity: ${getEntityId('this.entity_id') + '_network_speed_down'}
                default: '-'
                styles:
                  width: 90px
                  text-align: left
              - icon: mdi:upload
              - entity: ${getEntityId('this.entity_id') + '_network_total_up'}
                default: '-'
                styles:
                  width: 90px
                  text-align: left
              - entity: ${getEntityId('this.entity_id') + '_network_total_down'}
                default: '-'
                styles:
                  width: 90px
                  text-align: left
          entities:
            - entities:
              layout_type: custom:horizontal-layout
              placeholder: this.entity_id1
              layout:
                width: 300
                max_width: 450
                max_cols: 4
              cards:
                entities:
                  - entity: this.entity_id1
                lower_bound: 0
                hours_to_show: 24
                points_per_hour: 60
                line_width: 1
                line_color: lightgreen
                type: custom:mini-graph-card
                show:
                  average: true
                  extrema: true
                  labels: true
                style: |
                  ha-card {
                   border-radius: 10px;
                   background-color: rgba(0, 0, 0, 0.0);
  layout_type: vertical
  layout_options:
    width: 1400
filter:
  include:
    - entity_id: switch.docker_*
sort:
  method: friendly_name
show_empty: true
unique: true
I am using a few different cards for that, should be possible to find out which ones are used. The only thing you need to do manually is to download the icons for the docker containers and put them into the folder HA uses to serve files.
Thank you!
Some adjustments were needed:
filter:
  include:
    - entity_id: switch.docker*
      options:
        variables:
          getEntityId: |
            entityid => {
        entities:
          - this.entity_id
        card:
          type: entities
          entities:
              open: true
              head:
                show_state: false
                image: >-
                  "${'/local/assets/img/logos/' +
                  states['this.entity_id'].attributes.friendly_name + '.png'}"
                entities:
                    name: Off / On
                    toggle: true
                    styles:
                      width: 200px
                      align: center
                  - icon: mdi:memory
                    styles:
                      width: 90px
                      text-align: left
                  - icon: mdi:memory
                    styles:
                      width: 90px
                      text-align: left
                  - icon: mdi:upload
                    default: '-'
                    styles:
                      width: 90px
                      text-align: left
                    default: '-'
                    styles:
                      width: 90px
                      text-align: left
                  - icon: mdi:upload
                    default: '-'
                    styles:
                      width: 90px
                      text-align: left
                    default: '-'
                    styles:
                      width: 90px
                      text-align: left
              entities:
                - type: custom:layout-card
                  layout:
                    width: 300
                    max_width: 450
                    max_cols: 4
                  entities:
                  cards:
                    entities:
                    lower_bound: 0
                    hours_to_show: 24
                    points_per_hour: 60
                    line_width: 1
                    show:
                      average: true
                      extrema: true
                      labels: true
                    style: |
                      ha-card {
sort:
show_empty: true
unique: true
card_param: cards
card:
  layout_options:
    width: 1400
Last point I don’t understand is:
entities:
                  layout:
                    width: 300
                    max_width: 450
                    max_cols: 4
                  entities:
                  placeholder: this.entity_id2
                  cards:
                    entities:
                      - entity: this.entity_id2
                    lower_bound: 0
                    hours_to_show: 24
                    points_per_hour: 60
                    line_width: 1
                    show:
                      average: true
                      extrema: true
                      labels: true
                    style: |
                      ha-card {
First time I see “placeholder” here. I understand how it should work but it doesn’t…
Well, you have completely exchanged a card for another one, so it is not surprising that it doesn’t work :wink:
I am using the easy-layout-card: Easy-Layout-Card: Duplicate cards for multiple entities
You have used the layout-card, which does not have this possibility(which is why I created the easy-layout-card)
OK! understood.
Sorry, I did a search on Google about this easy-layout-card and didn’t find it. I thought it was linked to an old version of layout-card.
Thank you for sharing and explanation.
I really like the result of this dashboard. What a nice job :wink:
