Correct. They are reported by the devices running ESPHone.
Ah ok thank you.
I just did and is working. Some commands from the link I sent you need some update but worked at the end.
Instead of: > apt install python-pip3
Use: apt install python3-pip
Instead of: > chmod x+a my_script.py
Use: chmod +x my_script.py
Those was the mistype/error I found on the guide a sent the link to you.
Hi @ValJr,
I have this advice/error:
root@proxmox:~# chmod +x my_script.py
root@proxmox:~# ./my_script.py
/usr/lib/python3/dist-packages/urllib3/connectionpool.py:849: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
InsecureRequestWarning)
root@proxmox:~#
Change https:// to http:// on the script URL
This error is because you don’t have SSL certificate
Neat. I tried to recreate this but the severity colours don’t change for me. Any chance you could share your config?
Very nice customisation Jim. What do the green bars under your devices signify?
I am monitoring them with a count template, I am using a custom:bar-card to produce the green bar and carefully choose the thresholds to change its colour, right count = green, anything under that = red, anything over that = orange.
Doesn´t work!
Sure thing:
animation:
speed: '1.5'
state: 'on'
direction: right
entities:
- entity: sensor.multisensor_feather_2_7
- entity: sensor.multisensor_feather_3_7
- entity: sensor.multisensor_feather_4_7
name: Bedroom 3 RSSI
- entity: sensor.multisensor_feather_5_7
- entity: sensor.rgb_strip_controler_6_4
- entity: sensor.front_door_wifi_signal_strength
height: 25px
max: '-30'
min: '-90'
positions:
icon: 'off'
indicator: inside
severity:
- color: var(--label-badge-green)
to: ''
- color: orange
to: '-67'
- color: var(--label-badge-red)
to: '-80'
style: |-
bar-card-name {
text-shadow: 1px 1px 5px black;
bar-card-value {
type: 'custom:bar-card'
The first time I tried I had many error messages. I google all of then and found the solutions there. Maybe that will work for you. What error message are you getting now?
Thanks for that. Your code made me realise my mistake when using negative numbers - the values from highest to lowest should have been the other way around. Changed my values to match yours and the colours are working as they should. Will still try your code as well and choose my favourite
With http, I have a lot of messages that can’t connect.
Maybe because in HA I’m using https:
http:
base_url: https://myhaip:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Sure. Here’s the sensor code to count all of the domains, credit to @petro for this. I was doing something similar but his method was much cleaner and simpler.
sensors:
#----- Count All Entities
total_entities:
entity_id: []
friendly_name: 'Entities'
icon_template: mdi:code-tags
value_template: "{{ states | count }}"
#----- Count Automations
total_automations:
entity_id: []
friendly_name: 'Automations'
icon_template: mdi:robot
value_template: "{{ states.automation | list | length }}"
#----- Count Binary Sensors
total_binary_sensors:
entity_id: []
friendly_name: 'Binary Sensors'
icon_template: mdi:checkbox-multiple-marked-circle
value_template: "{{ states.binary_sensor | list | length }}"
#----- Count Cameras
total_cameras:
entity_id: []
friendly_name: 'Cameras'
icon_template: mdi:cctv
value_template: "{{ states.camera | list | length }}"
#----- Count Counters (haha)
total_counters:
entity_id: []
friendly_name: 'Counters'
icon_template: mdi:counter
value_template: "{{ states.counter | list | length }}"
#----- Count Device Trackers
total_devicetrackers:
entity_id: []
friendly_name: 'Devices'
icon_template: mdi:cellphone-link
value_template: "{{ states.device_tracker | list | length }}"
#----- Count Groups
total_groups:
entity_id: []
friendly_name: 'Groups'
icon_template: mdi:group
value_template: "{{ states.group | list | length }}"
#----- Count Input Booleans
total_input_booleans:
entity_id: []
friendly_name: 'Input Booleans'
icon_template: mdi:toggle-switch
value_template: "{{ states.input_boolean | list | length }}"
#----- Count Input Datetimes
total_input_datetimes:
entity_id: []
friendly_name: 'Input Datetimes'
icon_template: mdi:calendar-clock
value_template: "{{ states.input_datetime | list | length }}"
#----- Count Input Numbers
total_input_numbers:
entity_id: []
friendly_name: 'Input Numbers'
icon_template: mdi:numeric
value_template: "{{ states.input_number | list | length }}"
#----- Count Input Selects
total_input_selects:
entity_id: sensor.date
friendly_name: 'Input Selects'
icon_template: mdi:format-align-justify
value_template: "{{ states.input_select | list | length }}"
#----- Count Input Texts
total_input_texts:
entity_id: []
friendly_name: 'Input Texts'
icon_template: mdi:alphabetical
value_template: "{{ states.input_text | list | length }}"
#----- Count Lights
total_lights:
friendly_name: 'Lights'
icon_template: mdi:lightbulb-on
value_template: "{{ states.light | list | length }}"
#----- Count Media Players
total_media_players:
entity_id: []
friendly_name: 'Media Players'
icon_template: mdi:cast-connected
value_template: "{{ states.media_player | list | length }}"
#----- Count Persons
total_persons:
entity_id: []
friendly_name: 'Persons'
icon_template: mdi:account-multiple
value_template: "{{ states.person | list | length }}"
#----- Count Remotes
total_remotes:
entity_id: []
friendly_name: 'Remotes'
icon_template: mdi:remote
value_template: "{{ states.remote | list | length }}"
#----- Count Scenes
total_scenes:
entity_id: []
friendly_name: 'Scenes'
icon_template: mdi:palette
value_template: "{{ states.scene | list | length }}"
#----- Count Scripts
total_scripts:
entity_id: []
friendly_name: 'Scripts'
icon_template: mdi:script-text-outline
value_template: "{{ states.script | list | length }}"
#----- Count Sensors
total_sensors:
entity_id: []
friendly_name: 'Sensors'
icon_template: mdi:pulse
value_template: "{{ states.sensor | list | length }}"
#----- Count Switches
total_switches:
entity_id: []
friendly_name: 'Switches'
icon_template: mdi:power-socket-us
value_template: "{{ states.switch | list | length }}"
#----- Count Timers
total_timers:
entity_id: []
friendly_name: 'Timers'
icon_template: mdi:timer
value_template: "{{ states.timer | list | length }}"
#----- Count Zones
total_zones:
entity_id: []
friendly_name: 'Zones'
icon_template: mdi:map-marker-radius
value_template: "{{ states.zone | list | length }}"
#----- Count Z-Wave Devices
total_zwave_devices:
entity_id: []
friendly_name: 'ZWave'
icon_template: mdi:z-wave
value_template: "{{ states.zwave | list | length }}"
automation:
###### UPDATE COUNTS
- alias: "System - Update Template Sensors"
initial_state: 'on'
platform: time_pattern
minutes: '/25'
- service: homeassistant.update_entity
entity_id:
- sensor.total_automations
- sensor.total_binary_sensors
- sensor.total_cameras
- sensor.total_counters
- sensor.total_devicetrackers
- sensor.total_entities
- sensor.total_groups
- sensor.total_input_booleans
- sensor.total_input_datetimes
- sensor.total_input_numbers
- sensor.total_input_selects
- sensor.total_input_texts
- sensor.total_lights
- sensor.total_media_players
- sensor.total_persons
- sensor.total_remotes
- sensor.total_scenes
- sensor.total_scripts
- sensor.total_sensors
- sensor.total_switches
- sensor.total_timers
- sensor.total_zones
- sensor.total_zwave_devices
And the code for the Lovelace view below. There’s LOTS of tap/hold actions in here, so make sure you read the comments and adjust it to your personal needs
#### HOME ASSISTANT INFO AT A GLANCE
- type: vertical-stack
cards:
- type: glance
columns: 5
show_name: true
entities:
- entity: sensor.total_sensors
- entity: sensor.total_automations
tap_action:
action: navigate
navigation_path: /config/automation
hold_action:
action: call-service
service: automation.reload # reloads automations when long-pressed
- entity: sensor.total_scripts
tap_action:
action: navigate
navigation_path: /config/script
hold_action:
service: script.reload # reloads scripts when long-pressed
- entity: sensor.total_devicetrackers
tap_action:
action: navigate
navigation_path: /config/devices/dashboard
- entity: sensor.total_switches
- entity: sensor.total_lights
tap_action:
action: navigate
navigation_path: /lovelace/lights # change to your Lovelace view for Lights
- entity: sensor.total_scenes
tap_action:
action: navigate
navigation_path: /config/scene/dashboard
hold_action:
service: scene.reload # reloads persons when long-pressed
- entity: sensor.total_zones
tap_action:
action: navigate
navigation_path: /config/zone
hold_action:
service: zone.reload # reloads zones when long-pressed
- entity: sensor.total_binary_sensors
- entity: sensor.total_input_booleans
hold_action:
service: input_boolean.reload # reloads input booleans when long-pressed
- entity: sensor.total_input_numbers
hold_action:
service: input_number.reload # reloads input numbers when long-pressed
- entity: sensor.total_input_texts
hold_action:
service: input_text.reload # reloads input texts when long-pressed
- entity: sensor.total_input_selects
hold_action:
service: input_select.reload # reloads input selects when long-pressed
- entity: sensor.total_media_players
tap_action:
action: navigate
navigation_path: /lovelace/media
- entity: sensor.total_cameras
tap_action:
action: navigate
navigation_path: /lovelace/cameras # change to your Lovelace view for Cameras
- entity: sensor.total_zwave_devices
tap_action:
action: navigate
navigation_path: /config/zwave
- entity: sensor.total_persons
tap_action:
action: navigate
navigation_path: /config/person
hold_action:
service: person.reload # reloads persons when long-pressed
- entity: sensor.total_timers
hold_action:
service: timer.reload # reloads timers when long-pressed
- entity: sensor.total_remotes
tap_action:
action: navigate
- entity: sensor.total_counters
tap_action:
action: navigate
navigation_path: /lovelace/overview #link to insights page instead, once i create it
- entity: sensor.total_entities
tap_action:
action: navigate
navigation_path: /developer-tools/state
hold_action:
action: navigate
navigation_path: /config/entities
- type: glance
columns: 4
show_name: true
entities:
- entity: sensor.home_assistant_v2_db
icon: mdi:database
hold_action:
service: recorder.purge # purges db keeping last 3 days only
keep_days: 3
repack: true
- entity: sensor.home_assistant_log
icon: mdi:file-alert-outline
tap_action:
action: navigate
navigation_path: /developer-tools/logs # goes to logs panel when tapped
hold_action:
service: system_log.clear # clears log in HA when long-pressed
- entity: sensor.time_online
hold_action:
service: homeassistant.restart # restarts HA when long-pressed
- entity: sensor.version_installed
tap_action:
action: navigate
navigation_path: /hassio/dashboard # goes to Hassio update section when tapped
You know what?
I actually really like the bar graph. I can see much more clearly where a problem may be occurring.
However I won’t be using this card, for two reasons:
It does not report it’s height correctly. No matter where I put it in my view it always stacks stupidly.
The visual editor is an appalling resource hog. Trying to edit this card generated warnings in Firefox, took 20-30 seconds to load and ended up using 10GB of memory! Closing firefox and restarting after I finished editing was the only way to release the memory used.
