System Monitoring - How does yours look?
You need to include show_state: true with your button card.
Are you trying to use the logo as a header as I did? You would need the image saved in your www folder.
Looks great, thanks for sharing.
The relevant code and screenshot, what I am doing wrong?
 - type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
          - type: button
            entity: sensor.msmalikhdd_cpu_utilization_total
            tap_action:
              action: more-info
              show_state: true
              show_name: false
              show_icon: true
            icon: mdi:memory
          - type: button
            entity: sensor.msmalikhdd_memory_usage_real
            tap_action:
              action: more-info
              show_state: true
              show_icon: true
            icon: mdi:memory
Your second button card doesn’t have show_state: true. I’m guessing there’s a few in there that are missing that line
EDIT: just check all your buttons for that line of code
I have four buttons all have that line. here is the complete code I have used internet images. I also need to re-scale the images and use those side-by-side horizontally.
mode: horizontal
show_header_toggle: false
cards:
  - type: picture
    image: https://upload.wikimedia.org/wikipedia/commons/4/48/Synology_Logo.svg
  - type: picture
    image: >-
      https://www.trustedreviews.com/wp-content/uploads/sites/54/2013/11/DS214play-angle-2-1-772x920.png
  - type: entities
    entities:
      - sensor.msmalikhdd_volume_1_used_space
    cards:
      - type: custom:mini-graph-card
        icon: mdi:network
        entities:
          - sensor.msmalikhdd_network_down
          - sensor.msmalikhdd_network_up
    cards:
        cards:
          - type: button
            tap_action:
              action: more-info
              show_state: true
              show_name: false
              show_icon: true
            icon: mdi:cpu-64-bit
          - type: button
            tap_action:
              action: more-info
              show_state: true
              show_icon: true
            icon: mdi:memory
    cards:
        cards:
          - type: button
            entity: sensor.msmalikhdd_volume_1_used_space
            tap_action:
              action: more-info
              name: Vol 1 space
              show_state: true
              show_icon: true
            icon: mdi:harddisk
          - type: button
            entity: sensor.msmalikhdd_volume_2_used_space
            tap_action:
              action: more-info
              show_state: true
              show_icon: true
            icon: mdi:harddisk
    cards:
        cards:
          - type: gauge
            min: 0
            max: 100
          - type: gauge
            min: 0
            max: 100
          - type: gauge
            entity: sensor.msmalikhdd_volume_1_volume_used
            min: 0
            max: 100
          - type: gauge
            entity: sensor.msmalikhdd_volume_2_volume_used
            min: 0
            max: 100
        cards:
          - type: button
            entity: sensor.msmalikhdd_drive_1_status
            name: Disk A Status
            show_icon: true
            show_state: true
          - type: button
            entity: sensor.msmalikhdd_drive_2_status
            name: Disk B Status
            show_state: true
        cards:
          - type: gauge
            entity: sensor.msmalikhdd_drive_1_temperature
            name: Disk A Temperaure
          - type: gauge
            entity: sensor.msmalikhdd_drive_2_temperature
            name: Disk B Temperature
It’s the indentation. You currently have show_state: true under the tap_action section but it needs to be two spaces left so it’s under the main button card section
Thanks, @sparkydave you saved my day. Updated code and update screenshot. Now I need to re-size the images and use both sides by side horizontally
mode: horizontal
cards:
  - type: picture
  - type: picture
    image: >-
  - type: entities
    entities:
    cards:
        icon: mdi:network
        entities:
    cards:
        cards:
          - type: button
            tap_action:
              action: more-info
            show_state: true
            show_name: false
            show_icon: true
      -     type: button
            tap_action:
              action: more-info
            show_state: true
            show_icon: true
            icon: mdi:memory
    cards:
        cards:
          - type: button
            tap_action:
              action: more-info
            name: Vol 1 space
            show_state: true
            show_icon: true
            icon: mdi:harddisk
          - type: button
            tap_action:
              action: more-info
            name: Volume 2 space
            show_state: true
            show_icon: true
            icon: mdi:harddisk
    cards:
        cards:
          - type: gauge
            min: 0
            max: 100
          - type: gauge
            min: 0
            max: 100
          - type: gauge
            min: 0
            max: 100
          - type: gauge
            min: 0
            max: 100
        cards:
          - type: button
            name: Disk A Status
            show_icon: true
            show_state: true
          - type: button
            name: Disk B Status
            show_state: true
        cards:
          - type: gauge
          - type: gauge
I’ve done a little more playing around…
type: custom:stack-in-card
mode: vertical
card_mod:
  style: |
    ha-card {
      background: url('/local/images/synology_ds218.jpg');
      background-size: cover;
cards:
  - type: entities
    entities:
      - sensor.synology_total_size_volume_1
    header:
      image: /local/images/synology_logo.jpg
      type: picture
    cards:
        cards:
          - type: gauge
            entity: sensor.synology_cpu_load_total
            min: 0
            max: 100
          - type: gauge
            entity: sensor.synology_memory_usage_real
            min: 0
            max: 100
          - type: gauge
            entity: sensor.synology_volume_used_volume_1
            min: 0
            max: 100
          - type: 'custom:button-card'
            color_type: blank-card
        cards:
          - type: button
            entity: sensor.synology_status_smart_sda
            name: Disk A Status
            show_icon: true
            show_state: true
          - type: button
            entity: sensor.synology_status_volume_1
            name: Volume 1 Status
            show_icon: true
            show_state: true
          - type: button
            entity: sensor.synology_status_smart_sdb
            name: Disk B Status
            show_state: true
        cards:
          - type: gauge
            entity: sensor.synology_temperature_sda
          - type: gauge
            entity: sensor.synology_temperature_sdb
I will play with it some more later to tidy it up, this was just a test more than anything.
My old Synology card actually used small red rectangles to change the LED’s on the image of the NAS if a disk was unhealthy. Was kinda cool but I had chosen not to use a background image.
Updated some of my cards with these methods:
@firstof9 Сan you share your configuration?
@firstof9 How you show Download and Upload graph (up and down)?
The sensor comes from netdata, but here’s the UI yaml:
      - type: custom:apexcharts-card
        config_templates: nas_chart
        header:
          title: NAS Throughput
        series:
          - entity: sensor.netdata_nas_network_rx
            transform: return x / 1000;
            unit: Mbit/s
            group_by:
              duration: 1h
              func: max
          - entity: sensor.netdata_nas_network_tx
            transform: return (x / 1000) * -1;
            unit: Mbit/s
            invert: true
            group_by:
              duration: 1h
              func: max
apex chart’s template:
apexcharts_card_templates:
  default:
    color_list:
      - red
      - green
      - blue
  nas_chart:
    graph_span: 12h
    stacked: true
    config_templates: default
    header:
      show: true
      show_states: true
      colorize_states: true
    all_series_config:
      stroke_width: 2
      opacity: 0.3
      type: column
Hello I ve created the sensor from systemmonitor for my raspberry HA.
Ho to delete the 2 decimal for mem and cpu used. Prefer 40% than 40,02%, it took less places in the cards.
Just popping my head back in after more then a year hiatus. I’ll have a bit of time up my sleeves for some custom UI work in the coming xmas weeks as I’m homeless whilst we do some renovations but I’ll have some freeking cool automations particularly if your into Whisky and have a large collection :wink:
Kind of a simple overview for me :slight_smile:
The load-shedding is for us in South Africa that has blackouts planned by our wonderful power company.
why is sensor.date the entity id? not sure if I get that part?
This is the old way of forcing the template to update daily. It no longer works.
A very simple but usefull System Monitoring Card
Hi, which card did you use for access point? thanks! :grinning_face_with_smiling_eyes:
