System Monitoring - How does yours look?
Yes of course! Enjoy it! For works properly you need install this HACS:
  • gap-card
  • vertical-stack-in-card
  • button-card
  • mini-graph-card
  • bar-card
  • apexcharts-card
I can’t insert code here because: Body is limited to 32000 characters; you entered 116347.
So, access here to get the code: Pastebin.com - Locked Paste (the passwd is my nickname)
Hi Kejszijo,
Is it possible to share your page.yaml and sensors from solaredge ? I’m using the same Solar inverter and this look more slick than mine :slight_smile:
Kr,
Bart
I have Shelly 3EM energy meter which provides the data. From Solaredge inverter I only get the produced energy.
So, If you don’t have 3-phase energy monitor, you can’t get this graphs.
Thanks for sharing.
Can you also share your custom sensors config? for example sensor.custom_nas_synology_hardware_version
Although you have different ways to get those values, in my case I have used Glances.
- platform: rest
  resource: http://your_device:61208/api/3/cpu
  value_template:  '{{ "ok" }}'
  json_attributes:
    - os_name
    - linux_distro
    - hr_name
Then you need to extract this attributes to generate new sensor, this is the code:
  sensors:
    restful_name_device_os_name:
      friendly_name: "Device X OS name"
      value_template: '{{ state_attr("restful_name_device_version", "os_name") }}'
  sensors:
    restful_name_device_linux_distro:
      friendly_name: "Device X Distro"
      value_template: '{{ state_attr("restful_name_device_version", "linux_distro") }}'
  sensors:
    restful_name_device_hr_name:
      friendly_name: "Device X HR"
      value_template: '{{ state_attr("restful_name_device_version", "hr_name") }}'
In this way you will create 1 sensor for each “json_attribute”, you will be able to treat each data as a sensor and not as an attribute (I personally like it better).
Extra help:
Looks very cool, how did you get these elegant “frames” around the “Top Titles” ?
Thanks :slight_smile:
Just a customized button-card.
Need the code?
yeah, i figured that, im trying to get it in to my theme, i got it rounded ( in my theme ), but i dont get the border_color or : px … so i guess i need to “apply” it to each card , or ?
I use anchors (same but different as Declutter Card) to keep the button config as templates.
Then I call them from the later code and can add/modify parameters from the template.
Put following code ABOVE views:
anchors:
  # Makes any card's inactive colors active
  card_mod_transparent: &card_mod_transparent
    style: |
      ha-card {
        background-color: transparent; border: none; box-shadow: none;
  # Makes any card's inactive colors active, with border
  card_mod_transparent_border: &card_mod_transparent_border
    style: |
      ha-card {
        background-color: transparent; border: 'solid 1px rgba(57,128,228)'; box-shadow: none;
  # BUTTON CB HEADER
  cb_header: &cb_header
    type: "custom:button-card"
    color_type: label-card
    color: rgb(44, 109, 214)
    styles:
      card:
        - background: none
        - height: 5px
        - border: "solid 1px rgba(57,128,228)"
  # BUTTON VERTICAL SPACER IN H-STACK
  cb_vertical_spacer: &cb_vertical_spacer
    type: custom:button-card
    color_type: blank-card
    styles:
      card:
        - background: none
        - height: 10px
Then You call the CB Header like this:
  - id: 0
    title: PAGE TITLE
    icon: mdi:home-variant
    cards:
      - type: vertical-stack
        cards:
          - <<: *cb_header
            name: NAME INSIDE THE BOX WITH ROUNDED CORNERS
          - <<: *cb_vertical_spacer
          - type: horizontal-stack
            cards:
              - type: custom:button-card
                <<: *card_mod_transparent
Use the - <<: *cb_header to call the template.
Use the - <<: *cb_vertical_spacer to insert a space between card inside a Horizontal Stack.
Use the <<: *card_mod_transparent to call the template to make your card 100% transparent.
You’re good to go! :+1:
Thanks alot for your help and inspiration, i figured it was “only” a header-bubble, and i got that working, thou i ended up hard-coding it in the “view” , so not using the “anchor” method, i did however used your “idea” , to get a little nicer looking cards :slight_smile:
Back playin around with my UI as my old one died 12 months ago and I haven’t really needed a UI as automations take care of everything but who doesn’t like a sexy UI.
Very nice indeed, good work!
Hi there,
I just received 10 room sensors which each have Temp / Humidity / LUX I have been searching for a nice way to display the informatino from them. Does anyone have any examples that they can share please?
I wouldn’t say my example is anything fancy… but
Thanx Dave!
Could you share a snippet of the code to get the two entity readings side by side like that. I would then as a third for the LUX readings.
I use the custom button card for my dashboard:
Here is the code:
aspect_ratio: 1/1
color: orange
color_off: dodgerblue
color_type: icon
custom_fields:
  bath: |
      if (states["input_boolean.bath_mode"].state === 'on')
      return `
      <span><span style='color: orange;'>${("fürdő mód be")}</span></span> `;
      if (states["input_boolean.bath_mode"].state === 'off')
      return `<span><span style='color: grey;'>${("fürdő mód ki")}</span></span> `;
  humidity: |
      return `<ha-icon
        icon="mdi:water-percent"
        style="width: 14px; height: 14px; color: dodgerblue;">
        </ha-icon><span>${states["sensor.humidity_158d00023f4eae"].state}%</span>`
  illumination: |
      return `<ha-icon
        icon="mdi:track-light"
        style="width: 14px; height: 14px; color: deepskyblue;">
        </ha-icon> <span>${states["sensor.illumination_158d0002b48dd2"].state}lx</span>`
  light: |
      if (states["light.bathroom"].state === 'on')
      return `<ha-icon
        icon="bha:ceiling-lamp" style="width: 12px; height: 12px; color: var(--button-card-light-color); "></ha-icon>
      <span><span style='color: var(--text-color-sensor);'>${("lámpa be")}</span></span> `;
      if (states["light.bathroom"].state === 'off')
      return `<ha-icon
        icon="bha:ceiling-lamp" style="width: 12px; height: 12px; color: grey;"></ha-icon>
      <span><span style='color: grey;'>${("lámpa ki")}</span></span> `;
  move2: |
      if (states["binary_sensor.motion_sensor_158d0002b48dd2"].state === 'on')
      return `
      <span><span style='color: var(--text-color-sensor);'>${("foglalt")}</span></span> `;
      if (states["binary_sensor.motion_sensor_158d0002b48dd2"].state === 'off')
      return `<span><span style='color: ivory;'>${("szabad")}</span></span> `;
  nightlight: |
      if (states["light.bathroom_nightlight"].state === 'on')
      return `<ha-icon
        icon="mdi:weather-night" style="width: 12px; height: 12px; color: var(--button-card-light-color); "></ha-icon>
      <span><span style='color: var(--text-color-sensor);'>${("holdfény be")}</span></span> `;
      if (states["light.bathroom_nightlight"].state === 'off')
      return `<ha-icon
        icon="mdi:weather-night" style="width: 12px; height: 12px; color: grey;"></ha-icon>
      <span><span style='color: grey;'>${("holdfény ki")}</span></span> `;
  temp: |
      return `
         ${states['sensor.temperature_158d00023f4eae'].state}°C</span></span>`
entity: light.bathroom
icon: mdi:shower
styles:
  card:
    - background: linear-gradient(rgba(255,255,255,0.1) 50%, rgba(0,0,20,0.3) 50%)
    - border-radius: 15px
    - border: solid 1.5px rgba(57,128,228)
    - padding: 4%
    - color: ivory
    - font-size: 11px
    - text-shadow: 0px 0px 5px black
    - text-transform: capitalize
  custom_fields:
    bath:
      - align-self: middle
      - justify-self: start
      - font-size: 10px
      - font-weight: null
    humidity:
      - justify-self: end
      - font-size: 10px
      - color: deepskyblue
      - font-weight: bold
    illumination:
      - padding-bottom: 1px
    light:
    move2:
      - font-size: 10px
      - font-weight: bold
    nightlight:
      - padding-bottom: 2px
    temp:
      - justify-self: end
      - font-size: 14px
      - font-weight: bold
      - margin-top: '-10px'
  grid:
    - grid-template-areas: >-
        "i temp""n humidity""move2 move2""light light""nightlight
        nightlight""illumination illumination""bath bath"
    - grid-template-rows: 1fr 1fr min-content min-content min-content min-content
    - grid-template-columns: 1fr 1fr
  icon:
    - width: 45%
  img_cell:
    - justify-content: start
    - align-items: start
    - margin: none
  name:
    - font-weight: bold
    - font-size: 12px
    - color: white
tap_action:
  action: fire-dom-event
  browser_mod:
    command: popup
    card:
      entities:
        - entity: light.bathroom
          hide_when_off: true
          toggle: true
          type: custom:slider-entity-row
        - entity: light.bathroom_nightlight
          hide_when_off: true
          toggle: true
        - entity: input_boolean.bath_mode
      show_header_toggle: false
      style: |
        ha-card {
          --ha-card-background: 'rgba(250,0,20,0.8)';
          background-image: url("/local/pictures/cardback.png");
          background-repeat: no-repeat;
          background-size: 100% 100%;
          background-attachment: cover;
          background-position: center;
          border: solid 1.5px rgba(57,128,228);
          border-radius: 15px;
          box-shadow: none;
      type: entities
    title: fürdőszoba
Great! thank you, Over night imade a very simple standard cards option as below. I was hoping to find a dedicated sensor card from someones custom_component that might mimic the actual look of the physical sensore…
Sure. I’m pretty sure you can add a third row with this custom card.
type: entities
entities:
  - entity: sensor.lounge_multisensor_air_temperature
    type: custom:multiple-entity-row
    secondary_info: last-changed
    entities:
      - entity: sensor.lounge_multisensor_humidity
    show_state: false
  - entity: sensor.ensuite_ms6_air_temperature
    entities:
      - entity: sensor.ensuite_ms6_humidity
    show_state: false
  - entity: sensor.kitchen_multi_sensor_temperature
    entities:
      - entity: sensor.kitchen_multi_sensor_relative_humidity
    show_state: false
  - entity: sensor.passage_ms6_air_temperature
    entities:
      - entity: sensor.passage_ms6_humidity
    show_state: false
  - entity: sensor.gym_multisensor_air_temperature
    entities:
      - entity: sensor.gym_multisensor_humidity
    show_state: false
  - entity: sensor.garage_multisensor_air_temperature_2
    entities:
      - entity: sensor.garage_multisensor_humidity_2
    show_state: false
  - entity: sensor.shed_multisensor_air_temperature
    entities:
      - entity: sensor.shed_multisensor_humidity
    show_state: false
title: House Temps & Humidity
Hi Sean,
Just looking at an old posting of yours and I am interested in the counting you did of your domains. What I would like to make in my control panel is a percentage available of entities. Imagine 100 entities of which 88 are up and available, hence 88%. This a measure of health check of the system. This is my system monitor which contains of 2 pages. Operational parameters of the system and the Wi-Fi coverage:
So could you tell me how you established that count?
Thanx @krovachek
This is what I managed to hack from your code so far:
aspect_ratio: 1/1
color: grey
color_off: black
color_type: icon
custom_fields:
  humidity: |
      return `<ha-icon
        style="width: 48px; height: 48px; color: white;">
        </ha-icon><span>${states["sensor.luminance_sensor_humidity"].state} %</span>`
  illumination: |
      return `<ha-icon
        </ha-icon> <span>${states["sensor.luminance_sensor_luminosity"].state} lx</span>`
  temp: |
      return `<ha-icon
        icon="mdi:"
        </ha-icon> <span>${states['sensor.luminance_sensor_temperature'].state}°C</span></span>`
icon: []
styles:
  card:
    - padding: 4%
    - color: white
    - font-size: 48px
  custom_fields:
    humidity:
      - justify-self: end
      - font-size: 56px
      - color: white
      - font-weight: bold
    illumination:
      - justify-self: end
      - font-size: 56px
      - color: white
      - font-weight: bold
    temp:
      - justify-self: end
      - font-size: 100px
      - font-weight: bold
      - margin-top: 16px
  grid:
  icon:
    - width: 100%
  img_cell:
    - margin: none
  name:
    - font-weight: bold
    - font-size: 28px
    - color: white
tap_action:
  browser_mod:
    command: popup
    card:
      entities:
        - entity: sensor.average_temperature
        - entity: sensor.average_humidity
        - entity: sensor.average_luminance
      style: |
        ha-card {
          background-image: '/local/images/polygonal.jpg';
          box-shadow: none;
      type: entities
    title: Sensor Data
Grid Card:
      - type: grid
        cards:
          - aspect_ratio: 1/1
            color: black
            color_off: black
            color_type: icon
            custom_fields:
              humidity: |
                  return `<ha-icon
                    style="width: 12px; height: 0px; color: white;">
              illumination: |
                  return `<ha-icon
                    </ha-icon> <span>${states["sensor.luminance_sensor_luminosity"].state} lux</span>`
              temp: |
                  return `<ha-icon
                    icon="mdi:"
            icon: []
            font-size: 12px
            styles:
              card:
                - background: >-
                    linear-gradient(rgba(255,255,255,0.1) 45%, rgba(0,0,20,0.3)
                    50%)
                - padding: 4%
                - color: white
                - font-size: 12px
              custom_fields:
                humidity:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                illumination:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                temp:
                  - justify-self: end
                  - font-size: 52px
                  - font-weight: bold
                  - margin-top: 16px
              grid:
              icon:
                - width: 100%
              img_cell:
                - margin: none
              name:
                - font-weight: bold
                - font-size: 18px
                - color: white
            tap_action:
              browser_mod:
                command: popup
                card:
                  entities:
                  style: |
                    ha-card {
                      background-image: /local/images/polygonal.jpg;
                      box-shadow: none;
                  type: entities
                title: All Sensor Averages
          - aspect_ratio: 1/1
            color: black
            color_off: black
            color_type: icon
            custom_fields:
              humidity: |
                  return `<ha-icon
                    </ha-icon><span>${states["sensor.luminance_sensor_2_humidity"].state} %</span>`
              illumination: |
                  return `<ha-icon
                    </ha-icon> <span>${states["sensor.luminance_sensor_2_luminosity"].state} lux</span>`
              temp: |
                  return `<ha-icon
                    icon="mdi:"
                    </ha-icon> <span>${states['sensor.luminance_sensor_2_temperature'].state}°C</span></span>`
            icon: []
            font-size: 12px
            styles:
              card:
                - background: >-
                    50%)
                - padding: 4%
                - color: white
                - font-size: 12px
              custom_fields:
                humidity:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                illumination:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                temp:
                  - justify-self: end
                  - font-size: 52px
                  - font-weight: bold
                  - margin-top: 16px
              grid:
              icon:
                - width: 100%
              img_cell:
                - margin: none
              name:
                - font-weight: bold
                - font-size: 18px
                - color: white
            tap_action:
              browser_mod:
                command: popup
                card:
                  entities:
                  style: |
                    ha-card {
                      box-shadow: none;
                  type: entities
          - aspect_ratio: 1/1
            color: black
            color_off: black
            color_type: icon
            custom_fields:
              humidity: |
                  return `<ha-icon
                    </ha-icon><span>${states["sensor.luminance_sensor_3_humidity"].state} %</span>`
              illumination: |
                  return `<ha-icon
                    </ha-icon> <span>${states["sensor.luminance_sensor_3_luminosity"].state} lux</span>`
              temp: |
                  return `<ha-icon
                    icon="mdi:"
                    </ha-icon> <span>${states['sensor.luminance_sensor_3_temperature'].state}°C</span></span>`
            icon: []
            name: Lili Bedrm 3
            font-size: 12px
            styles:
              card:
                - background: >-
                    50%)
                - padding: 4%
                - color: white
                - font-size: 12px
              custom_fields:
                humidity:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                illumination:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                temp:
                  - justify-self: end
                  - font-size: 52px
                  - font-weight: bold
                  - margin-top: 16px
              grid:
              icon:
                - width: 100%
              img_cell:
                - margin: none
              name:
                - font-weight: bold
                - font-size: 18px
                - color: white
            tap_action:
              browser_mod:
                command: popup
                card:
                  entities:
                  style: |
                    ha-card {
                      box-shadow: none;
                  type: entities
          - aspect_ratio: 1/1
            color: black
            color_off: black
            color_type: icon
            custom_fields:
              humidity: |
                  return `<ha-icon
                    </ha-icon><span>${states["sensor.luminance_sensor_4_humidity"].state} %</span>`
              illumination: |
                  return `<ha-icon
                    </ha-icon> <span>${states["sensor.luminance_sensor_4_luminosity"].state} lux</span>`
              temp: |
                  return `<ha-icon
                    icon="mdi:"
                    </ha-icon> <span>${states['sensor.luminance_sensor_4_temperature'].state}°C</span></span>`
            icon: []
            name: Study Rm 4
            font-size: 12px
            styles:
              card:
                - background: >-
                    50%)
                - padding: 4%
                - color: white
                - font-size: 12px
              custom_fields:
                humidity:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                illumination:
                  - justify-self: end
                  - font-size: 24px
                  - color: white
                  - font-weight: bold
                temp:
                  - justify-self: end
                  - font-size: 52px
                  - font-weight: bold
                  - margin-top: 16px
              grid:
              icon:
                - width: 100%
              img_cell:
                - margin: none
              name:
                - font-weight: bold
                - font-size: 18px
                - color: white
            tap_action:
              browser_mod:
                command: popup
                card:
                  entities:
                  style: |
                    ha-card {
                      box-shadow: none;
                  type: entities
        columns: 2
