Here’s a good resource for SNMP OID info as well.
Anyone else seeing the:
Integration rpi_power not found when trying to verify its sensor platform.
… after upgrading to 0.92.0?
Would you mind sharing the way you counted the automations, sensors etc? I want to apply that on how many lights are ON.
Thanks for that but it does not work on my Chinese mini PC.
cat /sys/class/thermal/thermal_zone*/type
to view what zones you have, and then
cat /sys/class/thermal/thermal_zone*/temp
This sensor reports -262 on my Ubuntu NUC.
and replace * with 0,1,2,3…etc
Each core has its own sensor? Is there a F version?
great monitorings i see here.
I am wondering how you did this?
I am also planning to monitor some of my devices. Bute don‘t want to male things more complicated, e.g. just checking if it is online or some disk space. E.g. my other RPis or my router (FritzBox).
Anyone who can share his/her config here?
Thanks in advance,
Ralf
Awesome. It was thermal_zone2. Thank you.
Thanks for the share @bigstation
Any suggestion on how do I implememt to show how many lights are on?
sensors:
lights_on:
entity_id: sensor.time
friendly_name: Lights
unit_of_measurement: “On”
value_template: “{{ states.light|selectattr(‘state’, ‘equalto’, ‘on’)|list|length }}”
Thank you so much!
Dear,
Nice
Config please.
Hi Would you mind help out with sensors, i’m trying to retrieve CPU + HD temps without any success, tried installing lm-sensors, but when i’m finish installing and type the command sensors i’m receiving :
no sensors found make sure you loaded all the kernel drivers you need
tried to run sensors-detect without any success
i’m running Ubuntu 18.10 on virtualbox on mini pc that i have.
Any ideas how to help ?
Usually sensor data isn’t parsed to virtual machines.
What OS are you running on the mini pc?
win 10 pro
