System Monitoring - How does yours look?
Listing the entities defeats the purpose of this script. So you have to update it manually using this service: homeassistant.update_entity.
Call it from the dev tools services menu or from an automation.
      sensor_count:
        friendly_name: 'Number of Sensors'
        value_template: >
          {%- set domains = ['sensor'] -%}
          {%- for domain in domains -%}
            {%- for item in states[domain] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      automation_count:
        friendly_name: 'Number of Automations'
        value_template: >
          {%- set domains = ['automation'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      script_count:
        friendly_name: 'Number of Scripts'
        value_template: >
          {%- set domains = ['script'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      switch_count:
        friendly_name: 'Number of Switches'
        value_template: >
          {%- set domains = ['switch'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      binary_sensor_count:
        friendly_name: 'Number of Binary Sensors'
        value_template: >
          {%- set domains = ['binary_sensor'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      lights_count:
        friendly_name: 'Number of Lights'
        value_template: >
          {%- set domains = ['light'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      tracker_count:
        friendly_name: 'Number of Devices'
        value_template: >
          {%- set domains = ['device_tracker'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      camera_count:
        value_template: >
          {%- set domains = ['camera'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      fan_count:
        value_template: >
          {%- set domains = ['fan'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      media_player_count:
        value_template: >
          {%- set domains = ['media_player'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
      plant_count:
        value_template: >
          {%- set domains = ['plant'] -%}
              {% if loop.first %}
                {{loop.length}}
              {% endif %}
            {%- endfor -%}
          {%- endfor -%}
Monitoring Spam
Looks great! can you share the configs?
Very clean overview
What theme do you use and please share you config.
How are you getting the info for your remaining space on the NAS drives?
Also I wouldn’t mind seeing your config for the washing machine status too
Impressive… Oh my… Amazing!
I need more of your config!
Can you share your vacuum card and what coffee machine are you using?
@Sjeff, @elRadix, @Yoinkz
you can find details for my latest lovelace here As I don’t want to hijack this thread.
@getsmokes I use snmp to pull info from my NAS Drives, some drives already supported in HA.
My Coffee Machine is a cheap Aldi Pod one for around $100AUD. I have installed ultrasonic sensors in the water and waste reservoirs and have a weight sensor telling me how pods I have left.
Hey @SeanM, I noticed your Zwave count is empty, I get that too. Sometimes it shows the correct number and sometimes it’s just blank. Do you get that too or did you manage to fix yours?
Here’s how I setup mine to count Zwave devices. (thanks to @klogg)
zwave_count:
  friendly_name: Zwave Devices
  entity_id: sensor.date
  value_template: >
    {%- set domains = ['zwave'] -%}
        {% if loop.first %}
          {{loop.length}}
        {% endif %}
      {%- endfor -%}
    {%- endfor -%}
When the date changes, it’ll update the count.
Hi all
Anyone monitoring some Proxmox virtualizer data?
I would like to know CPU temp, but since the OS is the virtualizer don’t know how to do it!
From within the Proxmox Shell I used
apt-get install lm-sensors
sensors-detect
watch -n 1 sensors
and with this I can see those value, but I don’t know how to get int the Hassio VM (based on Ubuntu 18.04 with Docker.
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +59.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +59.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +51.0°C  (high = +100.0°C, crit = +100.0°C)
Any suggestion or experience?
Like the gunners logo! :wink:
How did you manage to flatten the cards and lose the shadows? That looks so much better then the standard cards.
ha-card-box-shadow: '0 0px 0px 0 rgba(0, 0, 0, 0.0)'
Where do you apply this? I am still new to Home Assistant. :slight_smile:
Could you paste the code from the NAS? I am trying it here, but I can not get it to work. The connection with the nas is working but have no clue how to get get temperature. The temperature is not mentioned in the docs.
put it in configuration.yaml
frontend:
  themes:
	mytheme:
	  ha-card-background: 'rgba(255, 255, 255, 0.9)'
	  ha-card-border-radius: '2px'
	  primary-text-color: 'hsl(0, 0%, 45%)'
You can look here: https://www.home-assistant.io/components/snmp/
Every device has specific configuration. You need to look for specific OID in documentation or google it :slight_smile:
Ah ok, thanks. Never hear of that before. I will look into it!
