System update - websocket Api error
I can’t do the system update. This is since 12.4, i’ve waited for 13.0 but i get still error’s. There should be something with the WebSocket Api.
Who can help me, the log says:
Logger: homeassistant.components.websocket_api.http.connection
Bron: components/websocket_api/commands.py:241
integratie: Home Assistant WebSocket API (documentatie, problemen)
Eerst voorgekomen: 13:21:36 (1 gebeurtenissen)
Laatst gelogd: 13:21:36
[281472449608528] Unexpected exception
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 213, in async_install
await async_update_os(self.hass, version)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 57, in _wrapper
data = await funct(*argv, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 224, in async_update_os
return await hassio.send_command(
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 599, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: Unknown error, see supervisor
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 241, in handle_call_service
response = await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 2763, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2806, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 999, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1071, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 154, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 458, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 215, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Operating System: Unknown error, see supervisor
Hey!
Almost the same issue here…
Did you solve it?
Tks.
No, i’ve been searching but I’ve still got it sadly.
I’ve found there is a reported issue: HAOS 13.1 upgrade. unable to boot - Installation - Home Assistant Community (home-assistant.io)
I’ll omit this update hoping next one will fix it.
