Any advice how to troubleshoot this would be welcomed.
My HA (OS8.1, core 2022.5.5) which is freshly built (I have HACS installed with EdgeOS, BLE integrations and 10 smart plugs via Conbee) but OS keeps crashing consistently after 1-2 days of rebooting. Disk usage is less than 5GB out 32GB. Same thing happened with OS 7.6.
I do not see anyone else complaining about it so makes me wonder if this is somehow related to Synology 7.0.1 and VM I’m running it?
Errors that keep repeating in 1000’s are (with varying numerical values):
sd 0:0:0:0: [sda] tag#0 access beyond end of device
systemd-journald[108]: Failed to write entry (12 items, 345 bytes), ignoring : Read-only file system
I have also seen on console the following message:
ata1.00: failed command: FLUSH CACHE
Any ideas what to check and why this keeps happening.
Is there a setting I need to change in Synology VM that will stop this?
I have not been able to get ssh access to actual OS that runs the HA Docker to see what’s going on.
Does anyone know how to ssh into the OS running HA Docker, as it seem like there is something going with systemd-journald. I install SSH within HA but it did not give me proper access as docker didn’t exist in system I accessed via ssh and there were no logs at all in /var/log/
Much appreciate any help I can get.
