Systemmonitor Drive argument config
Good morning.
Configuration is - Synology NAS running Docker.
I am very new to this so i am sorry if this is a silly question.
I can monitor the local NAS drive with arg: / but my questions are:
  1. what is the argument to monitor the drive of a second NAS
  2. what is the argument to monitor the drive of a Windows PC.
Please remember i am new to this and will need full instructions.
many thanks in advance
Ady
Have you integrate it to HA? It should be auto-discovery.
You can also do a manual setup as instructed here-
For Windows, you can try-
Thank you for the quick reply. i have just checked and you are correct.
I didnt even notice the “volume1” drive space for the second NAS. #tick!
This just leaves the issue of the Windows PC?
You can try to use Open Hardware Monitor
Will have a look, thank you
Please note that you should give your Windows PC a static IP address, because after setting up you need to add this line to your configuration.yaml.
# Example configuration.yaml entry
  - platform: openhardwaremonitor
    host: IP_ADDRESS
All PC’s and NAS are static. I have HS running on a PC and it is good BUT hard drive is looking poor so want to get it on NAS
i think openhardwaremonitor needs “remote web server”. not sure how to get that running on Windows 10
Sorry, I don’t personally use openhardwaremonitor. For setting up remote web server, you can watch Allowing remote Web Server or FTP access in Windows 10 (2020).
Note: I don’t know if it works or not for openhardwaremonitor.
Goodluck :slight_smile:
i cant find out how to, or even if it is possible to run Remote Web Server on Windows 10.
You can read more on this thread-
Some users also experience an error in using openhardwaremonitor on Windows 10.
Great, that worked. Any idea on the config for multiple Windows PC'c? this didnt work
OpenHardware
  • platform: openhardwaremonitor
    host: 192.168.1.9
    host: 192.168.1.7
Nice! Please use codeblock when you are pasting codes/YAML as written here. It will make it easier for others to see your codes - as with YAML you need to pay attention with indentation.
Maybe you can try-
    host: IP_ADDRESS01
    host: IP_ADDRESS02
All working, many thanks
Have a good day
