Tado X integration
I recently purchased a set of latest generation tado valves, the Tado X. Unfortunately I saw that the official integration (cloud) does not offer any control of them, while the only possibility is to manage them via Matter integration which however does not offer all the controls provided by the app. In particular, the thing that is missing most is the ability to set the “away” mode; at the moment it is only possible to set the “heating” or “off” mode which however sets the valves to the anti-freeze temperature (5 degrees). We hope that this feature can be implemented as soon as possible. Thank you.
you should use the search first :wink: please go ahead in
sorry, I was thinking of creating a new proposal to increase the number of requests…
with this you will accomplish the exact opposite of that what you want, since the votes for this request will be shared over multiple requests, and those weakens the single request.
Anyway, the Feature Request Guidelines clearly states
Remember to search the entire Feature Requests Catalog first before you add a duplicate. If you find one that is close to what you would like to see, consider voting for that one instead. The forum tool is pretty good at guessing about things that are similar, and search is also a good idea.
If your Feature Request is determined by us to be a duplicate, it will be immediately closed.
Closed as a duplicate. Please vote and comment on the FR linked above.
