yes with everything
i have created 3 scene for every cover:
open
close
ventilation
but they wonât work (sometimes they do but i canât put my finger on it when they donât.)
As soon as i edit the scene the cover will assume the right position. But if run the scene it doesnât.
(5 minutes later): now they suddenly work???
- id: â1592740544581â
name: Rolluik zitkamer open
entities:
cover.rolluik_zitkamer_2:
current_position: 100
device_class: shutter
friendly_name: Rolluik zithoek
rssi_level: 36
state: open
supported_features: 15
type: io:RollerShutterGenericIOComponent
uiclass: RollerShutter
widget: PositionableRollerShutter - id: â1592740553048â
name: Rolluik zitkamer dicht
entities:
current_position: 0
rssi_level: 36
state: open
widget: PositionableRollerShutter - id: â1592740564399â
name: Rolluik zitkamer ventilatie
entities:
current_position: 25
rssi_level: 36
state: open
Hi Mick,
I noticed that you solved the tilt issue.
It is working for me with the buttons in lovelace and the slider when I select the device.
But the slider provided through custom:slider-entity-row is not working.
The same slider is working for sinilus covers.
Can you take a look at this to?
This is not related to the Tahoma component probably. custom:slider-entity-row
needs to support set_tilt_position
. For the slats of your pergola, I implemented it as tilt_position
instead of position
You should be able to set the attribute to tilt
, afterwards it should work. GitHub - thomasloven/lovelace-slider-entity-row: đš Add sliders to entity cards
Thanks, indeed solved with attribute âtiltâ
I am on 1.3.
My electricity meters are discovered but they donât report any measurement. Just âUnknownâ.
uiclass: ElectricitySensor
widget: CumulativeElectricPowerConsumptionSensor
type: 'io:TotalElectricalEnergyConsumptionIOSystemSensor'
unit_of_measurement: W
friendly_name: Compteur
device_class: power
@lseufer could you create a new issue on Github? https://github.com/iMicknl/ha-tahoma/issues/new/choose. We should be able to solve this if we receive a few more details.
Is this still an issue, @hans80? If so, could you create an issue on Github and include your automations and devices there?
Hi all,
Large update in version 1.4! Lots of your reports and improvements are included.
Please let us know if this works as expected, and continue reporting any issue or feature missing!
Cheers
Tahoma integration is no longer working for me - not sure if it is because of the Somfy Tahoma update yesterday or the update of the integration to 1.4. I noticed that after a restart of HA the devices were all offline. In HACS I was offered to update the Somfy Tahoma integration to 1.4 which I did. After a reboot the devices were still offline. I deleted the Tahoma integration from Configuration and tried to add it again, but now I get an error when the credentials are validated:
ValueError: Active state 'core:NameState' has not been defined: {"creationTime": 1593523120000, "lastUpdateTime": 1593523120000, "label": "OGP KNX Bridge", "deviceURL": "ogp://1227-5319-5336/00000BE8", "shortcut": false, "controllableName": "ogp:Bridge", "definition": {"commands": [{"commandName": "sendPrivate", "nparams": 1}], "states": [{"type": "DataState", "qualifiedName": "core:Private10State"}, {"type": "DataState", "qualifiedName": "core:Private1State"}, {"type": "DataState", "qualifiedName": "core:Private2State"}, {"type": "DataState", "qualifiedName": "core:Private3State"}, {"type": "DataState", "qualifiedName": "core:Private4State"}, {"type": "DataState", "qualifiedName": "core:Private5State"}, {"type": "DataState", "qualifiedName": "core:Private6State"}, {"type": "DataState", "qualifiedName": "core:Private7State"}, {"type": "DataState", "qualifiedName": "core:Private8State"}, {"type": "DataState", "qualifiedName": "core:Private9State"}], "dataProperties": [], "widgetName": "DynamicBridge", "uiClass": "ProtocolGateway", "qualifiedName": "ogp:Bridge", "type": "ACTUATOR"}, "states": [{"name": "core:NameState", "type": 3, "value": "OGP KNX Bridge"}], "attributes": [{"name": "core:Technology", "type": 3, "value": "KNX"}, {"name": "ogp:Features", "type": 10, "value": [{"name": "private"}]}, {"name": "core:ManufacturerReference", "type": 3, "value": "OGP KNX Bridge"}, {"name": "core:Manufacturer", "type": 3, "value": "Overkiz"}], "available": true, "enabled": true, "placeOID": "6af77b24-bf47-4670-b112-ab85d86d670e", "widget": "DynamicBridge", "type": 1, "oid": "7b16b823-ac68-4363-a735-7cbce6f4a634", "uiClass": "ProtocolGateway"}
It seems indeed that the update did break some stuff⌠not sure yet whatâs going on to be honest. What box are you using? Iâve never seen the âOGP KNX Bridgeâ before.
do you own a somfy smart lock by any chance?
I have no idea where this âOGP KNX Bridgeâ is coming from. I dont have KNX⌠I have the Tahoma Box. I saw someone else posting the exact same error message in another thread.
Btw, I tried the Somfy integration and that works fine - but of course doesnt really help me as Somfy integration doesnt support the window sensors.
in any case, many thanks Vincent for the incredible work you are doing. Lets hope it is a solveable problemâŚ
No, not Somfy but I do have a Nuki.
Ok, I thought from our code that it could be related to the lock, but obviously notâŚ
Do you have a Traceback (most recent call last):
message before the ValueError
Yes, sorry. Should have included that:
File "/config/custom_components/tahoma/config_flow.py", line 92, in async_step_user
info = await validate_input(self.hass, user_input)
File "/config/custom_components/tahoma/config_flow.py", line 48, in validate_input
await hass.async_add_executor_job(controller.get_setup)
File "/config/custom_components/tahoma/tahoma_api.py", line 180, in get_setup
self._get_setup(result)
File "/config/custom_components/tahoma/tahoma_api.py", line 190, in _get_setup
device = Device(self, device_data)
File "/config/custom_components/tahoma/tahoma_api.py", line 634, in __init__
that helps a lot, and should be fixable!
could you try this fix by downloading this zip, and replacing the directory tahoma
installed by HACS by the one in the zip, and restarting HA?
That worked !
Thank you so much!!
Thanks, this will be in the next release. keep your branch until then!
