We are working with @imick at refactoring and improving the Tahoma core component. At the moment this is done as a custom component installable through HACS, and available here: https://github.com/iMicknl/ha-tahoma.
A first big change is the use of config flow. Once installed, go to Configuration -> Integration and look for Tahoma. Input your login and password and enjoy the component!
The other big change is automatic discovery of the devices instead of hard coding every single one of them. Thus this version should have more devices compatible out of the box.
A lot of work still needs to be done. We need people to test it and report bugs, missing integrations, etc.
First of all thanks a lot for you efforts to make it better.
I’m currently using the somfy plugin in hassio but that doesn’t show my RTS zonnescherm:).
So i stumbled on your integration.
I was able to install it through HACS (it shows in their integrations page), but it won’t show up in my integrations page of hassio. Any idea what im doing wrong?
If you go to Settings > Integrations > +, you are missing the Somfy TaHoma integration in the list, is that right?
Could you tell me which version you are using via HACS? If it doesn’t show up in the Integrations page, you could try clearing your browser cache. I have not faced this myself, however I have seen this issue before with other components and HACS.
ok so my sunscreen is “out”. Im trying to bring it back in but the button for that is greyed out…
but i can move the slider and it will change the amount of “roll out” what ever you call that:)
after that the button isn’t greyed out anymore…
But if i use the slider to open it completely the button gets greyed out again…
my regular IO devices work fine!
but im missing my rtfs roofwindow opener…
I have the io:BioclimaticPergolaIOComponent device as well . Maybe the latest changes have broken this component, since we moved from tilt_position to current_tilt_position. Let me try the change this over the weekend. Does the slider work for you?
As Vincent said, would be great if you could create an issue for the light problem (new-device) and for the Pergola (bug). We didn’t implement color switching yet, thus more details of your device would be appreciated!
This should be fixed in the beta version installable through HACS. Can you confirm?
Note that up and down should work, but we have no way to retrieve the current state as it’s not part of what’s given by the TaHoma api…
