as discussed here, the integration uses the topic
stat/shutter/xxx/SHUTTER1
to read the position of the cover. This topic is only sent once after the cover reached his new position.
Another topic is send while the cover actually moves.
stat/shutter/xxx/RESULT {“Shutter1”:{“Position”:74,“Direction”:-1,“Target”:0,“Tilt”:0}}
stat/shutter/xxx/RESULT {“Shutter1”:{“Position”:73,“Direction”:-1,“Target”:0,“Tilt”:0}}
stat/shutter/xxx/RESULT {“Shutter1”:{“Position”:64,“Direction”:-1,“Target”:0,“Tilt”:0}}
Using this allows to update cover status in the UI very close to the actual movement.
In the above post I show how I created an mqtt cover item that uses these RESULT topics to update the position status (in case someone is interested). Works fine since a few years now. But I’d prefer to use the integration. Much less work to do.
Thanks, Dieter
