Hi Guys,
i have some Cover-Blinds and all the states are exposed to hass-io. So i can see the sensor-informations for Position, Target, Direction.
But the values get not updated in time. It looks like they get pulled instead of pushed. Sometimes i can see the Direction (1 = Up, -1 = Down, 0 = Do nothing). But in most cases not. I think that a process is quering the tasmotas every 60 seconds.
My automatisation scripts rely on the Direction Status.
How can i improve the update interval?
With MQTT i can see the direction every second to be updated via push notification.
But with plain TASMOTA-Integration not.
7:45:54.560 MQT: ro/stat/sys-04/STATUS10 = {"StatusSNS":{"Time":"2021-12-14T17:45:54","ANALOG":{"A0":182},"Shutter1":{"Position":76,"Direction":0,"Target":76},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}}
17:46:48.440 MQT: ro/tele/sys-04/STATE = {"Time":"2021-12-14T17:46:48","Uptime":"0T23:33:11","UptimeSec":84791,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","POWER5":"OFF","POWER6":"OFF","POWER7":"OFF","POWER8":"OFF","Wifi":{"AP":1,"SSId":"iot.rsm-connect.net","BSSId":"E2:63:DA:15:DB:25","Channel":6,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":2,"Downtime":"0T00:02:54"}}
17:46:48.485 MQT: ro/tele/sys-04/SENSOR = {"Time":"2021-12-14T17:46:48","ANALOG":{"A0":158},"Shutter1":{"Position":76,"Direction":0,"Target":76},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:16.164 MQT: ro/stat/sys-04/RESULT = {"POWER1":"ON"}
17:48:16.166 MQT: ro/stat/sys-04/POWER1 = ON
17:48:16.169 MQT: ro/stat/sys-04/RESULT = {"ShutterOpen1":100}
17:48:16.174 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":76,"Direction":1,"Target":100}}
17:48:16.408 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":77,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:17.407 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":80,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:18.408 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":84,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:19.416 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":88,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:20.417 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":92,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:21.418 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":96,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:22.417 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":100,"Direction":1,"Target":100},"Shutter2":{"Position":46,"Direction":0,"Target":46},"Shutter3":{"Position":0,"Direction":0,"Target":0},"Shutter4":{"Position":0,"Direction":0,"Target":0}}
17:48:22.517 MQT: ro/stat/sys-04/RESULT = {"POWER1":"OFF"}
17:48:22.522 MQT: ro/stat/sys-04/POWER1 = OFF
17:48:23.027 MQT: ro/stat/sys-04/SHUTTER1 = 100
17:48:23.032 MQT: ro/stat/sys-04/RESULT = {"Shutter1":{"Position":100,"Direction":0,"Target":100}}
