I am trying to flash tasmota firmware onto it and i’m trying to find the correct pads to connect my flasher to.
There are no obvious pads to solder TX/RX to and the plug is very difficult to open completely.
I’we been unable to remove the PCB yet. I think i need to de-solder a few things before i can do that.
This is the chip on the board, the ESP8266EX https://github.com/arendst/Tasmota/wiki/GPIO-Locations
UART0 is on pin 24 and 25, upper leftmost pins and UART1 is on pin 14 and 23
I’m unsure if i should use UART 0 or 1 for flashing, i have tried probing for the pins on the front side of the PCB but they seem to go to a via and maybe end up on the bottom of the PCB which i have no access to yet.
Any help would be appreciated
I flashed a couple of these plugs with Tuya-Convert, but unfortunately bricked one when I was updating the firmware. Took it out of the socket too early
Do you maybe know a way to unbrick it, by using the soldering method and how this can be done? Any help is appreciated!
I have a number of these devices. One I was able to remove as there are screws holding the electronics unit to the plug pins. The other has soldered pins, so no way to ever remove it. On the underside of the picture, there are marked pads for the connection: 3.3V GND, TXD and TXD. they are unfortunately under the transformer a bit, but I used a screwdriver to pry it up a bit to get enough clearance and was able to reprogram serially. The one with the soldered pins, I have no idea how to connect. There are no connections on the top side other than the ESP8266 itself which is too fine for home soldering without breaking or melting the shell.
Slight update here if anyone needs it for those plugs.
If you remove the screw you can put the plug in a wise and gently squeeze the pins through the housing. Press on both pins at the same time.
Then you can get access to the backside of the PCB, where you have the tx/rx pins. Then it is just a normal flash of the ESP using a FTDI adaptor.
Sorry no, as they are now hidden behind stuff.
But remove the screw behind the sticker in the female end, so you open it up as shown in first post.
Then you can press the male pins through the housing and get access to the other side. Be aware of the wifi antenna ( the wire taped to the side.)
