I’m trying to use a Tasmota flashed ESP32 module to send temp/humidity data from a connected BLE Xaomi sensor to HA. I have a Xaomi LYWSD03MMC sensor flashed with this custom firmware.
I have a ESP32 board flashed with Tasmota hooked up to a PIR sensor brought into HA as a binary sensor used for motion detection automations, which works great:
15:51:34.358 RUL: SWITCH1#STATE=1 performs "Publish stat/laundry_pir/PIR ON"
15:51:34.368 MQT: stat/laundry_pir/PIR = ON
15:51:35.411 RUL: SWITCH1#STATE=0 performs "Publish stat/laundry_pir/PIR OFF"
15:51:35.424 MQT: stat/laundry_pir/PIR = OFF
I also have the BLE sensor flashed and connected to the ESP32:
The board temp and BLE sensor data seem to be publishing on MQTT correctly:
16:12:11.824 MQT: tele/laundry_pir/STATE = {"Time":"2021-05-26T16:12:11","Uptime":"0T15:39:48","UptimeSec":56388,"Heap":119,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":6,"Wifi":{"AP":1,"SSId":"****************","BSSId":"**:**:**:**:**:**","Channel":11,"RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:01:27"}}
16:12:11.854 MQT: tele/laundry_pir/SENSOR = {"Time":"2021-05-26T16:12:11","Switch1":"OFF","ESP32":{"Temperature":53.3},"TempUnit":"C"}
16:12:11.865 MQT: tele/laundry_pir/BLE = {"Time":"2021-05-26T16:12:11","BLEDevices":{"total":6,"************":{"i":0,"r":-78},"************":{"i":1,"r":-58},"************":{"i":2,"r":-93},"************":{"i":3,"r":-98},"************":{"i":4,"r":-96},"************":{"i":5,"r":-100}}}
16:12:11.896 MQT: tele/laundry_pir/BLE = {"Time":"2021-05-26T16:12:11","BLE":{"scans":2813,"adverts":1192170,"devices":6,"resets":0}}
16:12:24.819 MQT: tele/laundry_pir/SENSOR = {"Time":"2021-05-26T16:12:24","ATC******":{"mac":"************","Temperature":24.9,"Humidity":40.0,"DewPoint":10.3,"Battery":100,"RSSI":-61}}
But only the board temp is showing in HA:
Do I have to explicitly define the BLE data as entities to use them in HA, or did I miss something simple?
