via the Dobiss Evolution Pro 1.8.0
which configuring my master DO 5120pro, i use the touch as GUI for users access
in there i do not see the the address 41 for a relay…?
indeed,you dont see it, you need to know it, i have maxtool, i thinks its the same as evolution pro
i think i have the older evolition sx , does it look like below?
So relais A = 41 … and so on
i dont have the touch, i have created my own touch now with HA
i control covers, dimmers, lights, switches, and moods
if you have also a lightcell attached to dobiss, you can even read that value too, i dont do that though, i do it based on the sun: component
my dimmer was the most difficult part, to also actua read the dimmer state, seems dobiss works HEX , and also fro 00 … 90 , brightness value, and HA uses 0 … 255
sounds great on you do this! I believe we can make the GUI better with HA, touch is limited and the system should be able to do more, the electricity consumtion is the same and computers need to work
this is mine, where can i download maxtool?
seems your tools is the exact as maxtool, you dont need maxtool
you can see the relais and output also, so if you want to change “stopcontact inkom”, send “410000” and “4100001” to turn on/off that one so , 41 s relays 1 , 00 is the first output , 00 / 01 is on/off
i changed my code a lot btw, so all replys above in this thread is changed, i made it now “easier”, still a lot though, but i dont have shell commands anymore for every light/switch … just 1 variable shell command now
tricky HEX and DEC - but now we know - thanks for sharing
Always room to improve of course, can i have a copy as example and for review - coz now i don’t have a clue
what modules should i install from HA?
when this is done i’m more than happy to share my code, so other can do the same or even improve mine
what do you do with the ‘component the sun’…?
looking forward!
yeah, read this thread carefull, sometimes you need hex, sometimes you need dec, somtimes it starts with 00 , moods start with 01
its trial and error
sun: , well, automations , if sun goes down, i turn on some leds for example, control my screens , if its like windy, i do close my covers … just some cool stuff
i will post my new config later, maybe also usefull for @freezeke
ok, here is my config, its a lot, probably you need to read it 10 x times
so the because you can controll lights/switch outside HA? i wanted to know also the state of a light/switch/cover in my HA offcours,
thats why i poll every 10 secs my dobiss, so i can change the value_template
#sensor
- platform: command_line
command: shell_command.dobissreceive-
scan_interval: 15
dobissreceive-: python3 /config/python_scripts/dobissreceive.py
as you can see, i send to messages, the string is limited, so at the end i have 1 sensor, that contains everything in my house
the second string the ffffff… , is not used, but you need to send it, it needs complete bits, also the begin part is also the same : ED63300000000000000000000000AFAF
then it begins like 4205 , 420a , … so 42 is relays B in my case, 05 is the 6th output, as you can see work in hex here!!
so i will receive 00 or 01 if something is on / off
so now you already know states of lights/dimmers/covers/ …
in the .py file:
#!/usr/bin/python3
import socket
import codecs
import binascii
host = '192.168.0.10'
port = 1001
message = binascii.a2b_hex ("ED63300000000000000000000000AFAF4205420a410041014102410341044105410B42024304430A430B4408440943074306440A4500450145024503410A4106")
mySocket = socket.socket()
mySocket.connect((host,port))
mySocket.send(message)
data = mySocket.recv(1024)
data = binascii.hexlify(data).decode()
message2 = binascii.a2b_hex ("ED63300000000000000000000000AFAF42084207420943004206420442034400440144024403440444054406440743084309430243034305FFFFFFFFFFFFFFFF")
mySocket.send(message2)
data2 = mySocket.recv(1024)
data2 = binascii.hexlify(data2).decode()
print (data + '--' + data2)
mySocket.close()
second part, easy part, control a light/switch :
lights:
keukeneiland:
friendly_name: "Keuken Eiland"
value_template: "{{ states.sensor.prog.state[12:14] == '01' }}"
turn_on:
- service: shell_command.dobiss
data_template:
module: 41
power: 01
- service: shell_command.dobiss_state
data_template:
power: "on"
icon: "mdi:lightbulb-on"
api: "light.keukeneiland"
turn_off:
data_template:
module: 41
power: 00
data_template:
power: "off"
you see, when i turn on a light, i send 2 services
1 service is a shell_command, this is new, i made variables, here, so every light/switch code looks the same, only the module/id/power values change here…
so the shell_command.dobiss looks like :
dobiss: bash /config/python_scripts/dobiss.sh {{module}} {{id}} {{power}}
my bash script looks like, notice the $1 , $2 , $3 , those are my variables
#!/bin/bash
#dobiss 43 01 01 => dobiss: bash /config/dobiss.sh {{module}} {{id}} {{power}}
echo -e "\xED\x43\x31\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xAF\xAF\x"$1"\x"$2"\x"$3"" | nc 192.168.0.10 1001
so this should now turn on a light
for my second service, you see i do a curl, this is optional, if you dont do it, your light icon will only be changed aftre 10 seconds, base on the state sensorso i do a curl, so i change the icon instantly
also here i work now with variables, before i had for every light a shellcommand
so dobiss_state looks like :
dobiss_state: "curl -k -X POST -H \"Authorization: Bearer YOURBEARERHERE\" -d '{\"state\": \"{{power}}\",\"attributes\": {\"assumed_state\": true,\"friendly_name\": \"{{name}}\",\"icon\": \"{{icon}}\"}}' https://127.0.0.1:8123/api/states/{{api}}"
now, you also see a value template, this is is needed if you control a light outside HA, so when 10 sec scan_interval passes, this will change the light icon also
so if => [12:14] == ‘01’ => means character 12 to 14 , are 2 decimals, in that string you see in the sensor, if its 00 , light s off, if its 01 , light is on
second part, dimmers, not gonna comment here, just look at my code
dimmer1:
friendly_name: "Eethoek Raam"
value_template: "{{ states.sensor.prog.state[36:38] != '00' }}"
level_template: "{{ ( states('sensor.Prog')[36:38] | int(base=16) / 90 * 255 ) | int }}"
turn_on:
- service: input_number.set_value
entity_id: input_number.dimmer1
value: 255
- service: shell_command.dimmer1
- service: shell_command.state_dimmer1_on
turn_off:
value: 0
- service: shell_command.state_dimmer1_off
set_level:
data_template:
value: "{{ brightness }}"
#shell commands:
dimmer1: python3 /config/python_scripts/dimmer.py {{ '%02.f'%((((states('input_number.dimmer1') | float / 255 ) * 90) // 10) * 10) }}
state_dimmer1_on: "curl -k -X POST -H \"Authorization: Bearer BEARERHERE\" -d '{\"state\": \"on\",\"attributes\": {\"brightness\": {{states('input_number.dimmer1')}}, \"assumed_state\": true,\"friendly_name\": \"Eethoek Raam\",\"icon\": \"mdi:spotlight\", \"supported_features\": 1}}' https://127.0.0.1:8123/api/states/light.dimmer1"
state_dimmer1_off: "curl -k -X POST -H \"Authorization: Bearer BEARERHERE\" -d '{\"state\": \"off\",\"attributes\": {\"assumed_state\": true,\"friendly_name\": \"Eethoek Raam\",\"icon\": \"mdi:spotlight\", \"supported_features\": 1}}' https://127.0.0.1:8123/api/states/light.dimmer1"
#python file dimmer.py
#!/usr/bin/python3
import socket
import codecs
import binascii
import sys
## python3 dimmer.py 00-03 00-90
port = 1001
message = "ED43310000000000000000000000AFAF4510" + sys.argv[2]
string = binascii.a2b_hex (message)
mySocket.send(string)
mySocket.close()
#input number
dimmer1:
initial: 0
min: 0
max: 255
step: 1
now, last part , screens/covers
covers:
google_eetkamer:
friendly_name: Eetkamer
value_template: "{{ is_state('input_boolean.eetkamer', 'on' ) }}"
open_cover:
- service: cover.open_cover
entity_id: cover.eetkamer
close_cover:
- service: cover.close_cover
stop_cover:
- service: cover.stop_cover
covers:
cover1:
command_open: shell_command.screen1_open
command_close: shell_command.screen1_close
command_stop: shell_command.screens_stop
#shell command
screen1_open: echo -e "\xED\x43\x31\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xAF\xAF\x53\x13\x01" | nc 192.168.0.10 1001
screen1_close: echo -e "\xED\x43\x31\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xAF\xAF\x53\x14\x01" | nc 192.168.0.10 1001
screen2_open: echo -e "\xED\x43\x31\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xAF\xAF\x53\x15\x01" | nc 192.168.0.10 1001
#input boolean, to remeber the state after a HA restart !!
input_boolean:
eetkamer:
wauw cool - thanks for sharing keep you posted on the progress!
good luck, its a lot of trial and error, especially with the id’s and stuff
tip, just try some TCP commands directly from SSH terminal , like light on /off
also play with the python file, to get the state of all your lights, then you see in SSH also the output
Ow , and if you have ventilation, I control that too, I have like 3 modes, easy, normal, turbo, I just send a tcp mood command
Not yet - Belgium was not build in one day
New house?
Wow Fabio, a completely new approach
is this to reduce the load on the dobiss controller?
No , it’s just easier to copy paste lights/switches in the yaml files, only change relay id… No more shell/state commands anymore just 1… Easier to understand
For covers, that’s indeed new, I had stateless covers, now created statefull covers…
I have everything exposed to Google home assistant, so Google home app know the state of dobiss lights/covers now
Only for dimmers I still have separate shell commands, need to convert them also to 1
OK, cool stuff
Trying to understand here:
I change in my config to
#sensor - platform: command_line command: shell_command.dobissreceive- name: prog scan_interval: 15
And replace the dobissreive.py in config/python_scripts?
Rebuild the lights.yaml and for the bash script you lost me ![]()
yes, that sensors is still a pytjon script i run that stays the same
for the bash script (.sh) file, well, before, i had for every light, 2 shell commands, so 20 lights => 40 shell commands … and even more
now just 1 , i pass the arguments directly from the template light itsell, into the bash script
