I am trying to get my HASS to send a notification via Telegram. I have it working with a bot now but my question is, how do I send it to a group instead of just the bot?
Why? My wife and I have a family group so if the notification went there it would make more sense.
Hey Danesh, you can definitely use a group but there are a couple of stumbling blocks, one of which has already been mentioned (using a “-” sign for the group).
YES now it works espacially the easy way to geht the correct Group IDs is perfect.
That was the Solution for me. The Bot works in our group perfect now
Hey! I am just trying to find out how to send a message to a telegram group using HASS. I followed your tutorial, however, when I call the service “Telegram bot: Send message” to test it and supply the chat ID the GetIDs Bot was giving to me within my group, the message ends up in the private chat between me and my bot, and not in the group.
Do you maybe know why?
Ok I see I should be using notify.[name from configuration.yml]. Can I also attach videos and photos?
Nevermind, I had wrong chat ID for the group in configuration.yml. Now both the notifier as well as “Telegram bot: Send message” etc. works fine to send to the group.
