I’m working on a Esphome project that monitors my hydronic boiler temperatures and adjusts the high limit of the boiler. ( Show your most scary home made automation device )
It works well with the exception that HA displays the sensors from the device in both C and F however it calculates the reading as F.
Examples:
Displayed as:
And a graph card is shown with only ‘ºF’:
The module config is:
esphome:
platform: ESP8266
board: d1_mini_lite
wifi:
ssid: "#"
password: "#"
# Enable logging
logger:
# Enable Home Assistant API
api:
services:
- service: control_stepper
variables:
target: int
then:
- stepper.set_target:
target: !lambda 'return target;'
ota:
password: "#"
stepper:
- platform: uln2003
pin_a: D5
pin_b: D1
pin_c: D2
pin_d: D3
max_speed: 200 steps/s
step_mode: WAVE_DRIVE #HALF_STEP,WAVE_DRIVE,FULL_STEP
sleep_when_done: true
# Optional:
acceleration: inf
deceleration: inf
dallas:
- pin: D6
update_interval: 10s
- platform: dallas
address: 0xB30069E200001928
name: "Stepper box temp"
- platform: dallas
address: 0xDD01142FDF00C728
name: "Temperature East outside"
- platform: dallas
address: 0xE00316554741FF28
name: "Boiler in temperature near"
- platform: dallas
address: 0x7B04165130D5FF28
name: "Boiler out temperature near"
- platform: dallas
address: 0x5E02131A7D65AA28
name: "Boiler out temperature far"
- platform: dallas
address: 0x4902131A6393AA28
name: "Boiler in temperature far"
I think I maybe could make a template sensor to fix the display to only show ‘ºF’. But why is HA displaying both ‘ºF’ and ‘ºC’ , but calculates the values as ‘ºF’. even though the device sends out values in ‘ºC’ ?
Example:
INFO Reading configuration /config/esphome/stepper_test.yaml...
INFO Starting log output from stepper_test.local using esphome API
INFO Connecting to stepper_test.local:6053 (192.168.0.55)
INFO Successfully connected to stepper_test.local
[19:21:00][I][app:100]: ESPHome version 1.14.3 compiled on Dec 29 2019, 17:21:30
[19:21:00][C][wifi:415]: WiFi:
[19:21:00][C][wifi:283]: SSID: [redacted]
[19:21:00][C][wifi:284]: IP Address: 192.168.0.55
[19:21:00][C][wifi:286]: BSSID: [redacted]
[19:21:00][C][wifi:287]: Hostname: 'stepper_test'
[19:21:00][C][wifi:291]: Signal strength: -72 dB ▂▄▆█
[19:21:00][C][wifi:295]: Channel: 11
[19:21:00][C][wifi:296]: Subnet: 255.255.255.0
[19:21:00][C][wifi:297]: Gateway: 192.168.0.1
[19:21:00][C][wifi:298]: DNS1: 192.168.0.1
[19:21:00][C][wifi:299]: DNS2: (IP unset)
[19:21:00][C][uln2003.stepper:039]: ULN2003:
[19:21:00][C][uln2003.stepper:040]: Pin A: GPIO14 (Mode: OUTPUT)
[19:21:00][C][uln2003.stepper:041]: Pin B: GPIO5 (Mode: OUTPUT)
[19:21:00][C][uln2003.stepper:042]: Pin C: GPIO4 (Mode: OUTPUT)
[19:21:00][C][uln2003.stepper:043]: Pin D: GPIO0 (Mode: OUTPUT)
[19:21:00][C][uln2003.stepper:044]: Sleep when done: YES
[19:21:00][C][uln2003.stepper:057]: Step Mode: WAVE DRIVE
[19:21:00][C][logger:175]: Logger:
[19:21:00][C][logger:176]: Level: DEBUG
[19:21:00][C][logger:177]: Log Baud Rate: 115200
[19:21:00][C][logger:178]: Hardware UART: UART0
[19:21:00][C][dallas.sensor:070]: DallasComponent:
[19:21:00][C][dallas.sensor:071]: Pin: GPIO12 (Mode: INPUT)
[19:21:00][C][dallas.sensor:072]: Update Interval: 10.0s
[19:21:00][D][dallas.sensor:077]: Found sensors:
[19:21:00][D][dallas.sensor:080]: 0x5E02131A7D65AA28
[19:21:00][D][dallas.sensor:080]: 0x4902131A6393AA28
[19:21:00][D][dallas.sensor:080]: 0xB30069E200001928
[19:21:00][D][dallas.sensor:080]: 0xDD01142FDF00C728
[19:21:00][D][dallas.sensor:080]: 0xE00316554741FF28
[19:21:00][D][dallas.sensor:080]: 0x7B04165130D5FF28
[19:21:00][C][dallas.sensor:085]: Device 'Stepper box temp'
[19:21:00][C][dallas.sensor:085]: Unit of Measurement: '°C'
[19:21:00][C][dallas.sensor:085]: Accuracy Decimals: 1
[19:21:00][C][dallas.sensor:085]: Icon: 'mdi:thermometer'
[19:21:00][C][dallas.sensor:093]: Address: 0xB30069E200001928
[19:21:00][C][dallas.sensor:094]: Resolution: 12
[19:21:00][C][dallas.sensor:085]: Device 'Temperature East outside'
[19:21:00][C][dallas.sensor:093]: Address: 0xDD01142FDF00C728
[19:21:00][C][dallas.sensor:085]: Device 'Boiler in temperature near'
[19:21:00][C][dallas.sensor:093]: Address: 0xE00316554741FF28
[19:21:00][C][dallas.sensor:085]: Device 'Boiler out temperature near'
[19:21:00][C][dallas.sensor:093]: Address: 0x7B04165130D5FF28
[19:21:00][C][dallas.sensor:085]: Device 'Boiler out temperature far'
[19:21:00][C][dallas.sensor:093]: Address: 0x5E02131A7D65AA28
[19:21:00][C][dallas.sensor:085]: Device 'Boiler in temperature far'
[19:21:00](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[19:21:00][C][dallas.sensor:093]: Address: 0x4902131A6393AA28
[19:21:00][C][ota:029]: Over-The-Air Updates:
[19:21:00][C][ota:030]: Address: stepper_test.local:8266
[19:21:00][C][ota:032]: Using Password.
[19:21:00][C][api:095]: API Server:
[19:21:00][C][api:096]: Address: stepper_test.local:6053
[19:21:10][D][dallas.sensor:148]: 'Stepper box temp': Got Temperature=47.3°C
[19:21:10][D][sensor:092]: 'Stepper box temp': Sending state 47.31250 °C with 1 decimals of accuracy
[19:21:10][D][dallas.sensor:148]: 'Boiler in temperature near': Got Temperature=65.1°C
[19:21:10][D][sensor:092]: 'Boiler in temperature near': Sending state 65.12500 °C with 1 decimals of accuracy
[19:21:10][D][dallas.sensor:148]: 'Boiler in temperature far': Got Temperature=54.5°C
[19:21:10][D][sensor:092]: 'Boiler in temperature far': Sending state 54.50000 °C with 1 decimals of accuracy
[19:21:10][D][dallas.sensor:148]: 'Temperature East outside': Got Temperature=2.0°C
[19:21:10][D][sensor:092]: 'Temperature East outside': Sending state 2.00000 °C with 1 decimals of accuracy
[19:21:10][D][dallas.sensor:148]: 'Boiler out temperature near': Got Temperature=77.8°C
[19:21:10][D][sensor:092]: 'Boiler out temperature near': Sending state 77.75000 °C with 1 decimals of accuracy
[19:21:10](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
Many Thanks.
