Template help .. check for tomorrow
How do i check that tomorrow is “Store bededag”
{{ states(‘calendar.helligdage_i_danmark’) }} is off , because I check it today
You use the calendar.get_events service. There are many threads on this topic available… here are some that are similar to your question:
https://community.home-assistant.io/t/send-email-if-specific-calendar-event-is-present/687111/2
https://community.home-assistant.io/t/variable-help/675071/2
https://community.home-assistant.io/t/automation-to-set-a-variable-based-on-tomorrows-calendar/672035/3
It would be easier to give you a more specific answer if you give us more details about what you are trying to do.
Thanks, I want to make a true / false condition if the work “Store bededag” is in the calendar tomorrow
do i have to make a sensor for that, or can it be done in a template?
Those are not mutually exclusive options…
Post the script or automation you want to add the condition to and describe, specifically, when the condition needs to pass and when it should fail.
alias: Ny pre ferie helligdag
description: ""
  - platform: calendar
    event: start
    offset: "-9:0:0"
    entity_id: calendar.ferie
    event: start
    offset: "-9:0:5"
    entity_id: calendar.helligdage_i_danmark
    event: end
    offset: "-9:0:5"
    event: start
    offset: "-8:58:0"
    id: Helligdag start 2 dage efter hinanden
    event: end
    offset: "-9:0:5"
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: input_boolean.turn_off
            data: {}
              entity_id:
                - input_boolean.pre_ferie
      - conditions:
        sequence:
            data: {}
              entity_id:
      - conditions:
        sequence:
            data: {}
              entity_id:
      - conditions:
        sequence:
            data: {}
              entity_id:
      - conditions:
        sequence:
            data: {}
              entity_id:
    default: []
mode: restart
condition should check that the day tomorrow is not “Store bededag”
When using Calendar event triggers the event data is available as part of the trigger variable. You do not need to use the calendar.get_events service call or set up a sensor, you can use a normal template condition.
- condition: template
  value_template: "{{ trigger.calendar_event.summary is search('Store bededag') }}"
thanks , i will try that.
