Template select Exposed entities
Would really appreciate a way to retrieve in template a list of entities exposed to Assist. Even if exposed status could be available as an attribute, this would be helpful. Especially with the push to Assist / LLM, custom / spec functions to LLMs will absolutely need access to this kind of information. A good example of this is a template_value function that returns a current list of exposed entities for an LLM to update its understanding of the smart home.
Thanks in advance!
looking for the same, have you found a solution?
No solution yet.
looking for the same,any update?
Yup - this is CRITICAL to understanding context load.
I’m pretty sure [state_data] in the context, currently hard limited to 200000 tokens by Open AI in their largest models (ask me how I know - read Friday’s Party. Context is our current issue)
Yes my install is artificially bloated for a reason - but it points out I have no tools to understand what’s going on inside the state data.
expand(exposed_entites)
How big is it, how close am I to redline?
length(expand(exposed_entites))
(Yeah, it really is that simple then /4 for a rough token estimate.)
Or then you could then also take the entire length of the prompt do the calc,
add approximately 10000 tokens for a tools estimate.
Then you have an overall context load estimate. (But we NEED exposed_entities, especially with 2025.4 coming giving us start conversation and continued conversation what you can do with these will quickly gain speed, stay ahead of it with the tools…
vote for this feature
This can be done with a command line sensor
Took me a while to learn how, but this works…
# sensor_command_line_exposed_entities.yaml << This is a package
command_line:
# This sensor queries the .storage/core.entity_registry
# 1. It gathers all entities exposed to 'assist'
# 2. It deliberately excludes any entities that have been
#   disabled which have options.conversation.should_expose==true
- sensor:
    unique_id: exposed_entities
    command: >
      jq '{
      entities: (
          .data.entities[]
          | select(.options.conversation.should_expose==true)
          | select(.disabled_by? == null)
          | .entity_id
      | sort
      }' /config/.storage/core.entity_registry
    value_template: "{{ value_json.entities | length }}"
    json_attributes:
    - entities
recorder:
  exclude:
    entities:
    - sensor.exposed_entities
