to send me a summarized view of low battery devices or flowers, which needs water/soil I’m using that template:
{%- set threshold = 300 -%}
{%- for item in states['sensor'] if (item.state | int < threshold and item.state|int != 'unknown' and item.entity_id.endswith('conductivity')) -%}
{{ item.attributes.friendly_name }}: {{item.state}}{{item.attributes.unit_of_measurement }} {%- if not loop.last %}, {% endif -%}
{%- endfor -%}
Has anybody an idea how to avoid the error if the state exceeds 256 chars? Any other approach for that?
They way you have it implemented, there is no way to check the length of the string before reporting it.
You may want to get AppDaemon running and use python to handle this. You’d have more control over the strings you send out.
You could do one of the following as well:
shorten your fiendly names
remove your unit_of_measurement.
remove white space after colon and after comma.
Personally, i swapped all my automations to app daemon because I couldn’t do complicated functions with jinja because of the for loop restrictions, format restrictions, and general lack of functionality. Python is much better.
low_battery:
value_template: >
{%- set threshold = 15 -%}
{%- set domains = ['light', 'switch', 'sensor', 'binary_sensor', 'lock'] -%}
{%- for domain in domains -%}
{%- for item in states[domain] if ((item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold) or ("battery" in item.name | lower and ((item.state | int < threshold and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown"))) -%}
{{ item.attributes.friendly_name }}{%- if not loop.last %}, {% endif -%}
{%- endfor -%}
{%- endfor -%}
Don’t know if it works, but have you tried it without a template sensor?
Just templating the message you want to send?
service: notify.pushbullet
data_template:
title: 'New Home Assistant Release'
target: 'YOUR_TARGET_HERE' #See Pushbullet component for usage
message: "Home Assistant {{ states.updater.updater.state }} is now available."
Another solution would be to send a html mail via smtp.
This can be as long as you want.
EDIT: Works! Tried it with the example of the templates tool.
- service: notify.pushsafer
data_template:
message: >-
{% for state in states.sensor -%}
{%- if loop.first %}The {% elif loop.last %} and the {% else %}, the {% endif -%}
{{ state.name | lower }} is {{state.state_with_unit}}
{%- endfor %}
