Hello User,
how can i use copy & paste in the " Terminal & SSH Current version: 9.6.1" HAOS add-on?
henrya
Hello User,
henrya
From memory I think it is this:
CTRL + INSERT to copy.
SHIFT + INSERT to paste.
I don’t get success with Ctrl + Insert to copy anything.
What is (c)?
My browser Google Chrome Version 111.0.5563.146 (Offizieller Build) (64-Bit)
Old thread Copy and paste with the system clipboard in SSH & Web Terminal Addon - #5 by gostest
Where can i read the manual for Terminal & SSH?
Oh sorry that’s for the Community Addon,
The Home Assistant Community Add-on: SSH & Web doesn’t work in my case.
Error: 502: Bad Gateway
Options ssh
username: hassio
password: secretpassword
authorized_keys: []
sftp: false
compatibility_mode: false
allow_agent_forwarding: false
allow_remote_port_forwarding: false
allow_tcp_forwarding: false
I am also having this problem. I try to enter a password in between the double quotes and hit save. I go to the log tab and it tells me it isn’t configured. Go back to the configuration tab and everything is default again. I have uninstalled and reinstalled it. Restarted home assistant in between and I can’t get this to work.
I’ve resorted to using the other addon: Terminal & SSH. Which is a native terminal without the misconfigured tmux that comes with the other addon.
Same question here with Terminal & SSH Current version: 9.15.0
CTRL/SHIFT/whatever does not work, nothing gets copied, nothing gets pasted.
I find it hard to believe that such a basic and simple task of copy&paste is not working in homeassistant.
CRTL + SHIFT + V worked for me
