Tesla Custom Integration stopped working
This integration has not been working for a few days.
Here are the logs.
I am a novice, so I don’t know what this means - or what to do about it.
I’ve tried deleting the integration thinking that a fresh reinstall might work. But it doesn’t uninstall.
Any help would be appreciated!
Your version of the custom integration must be a little old. Which version is it?
I don’t know because I finally was able to delete it! I was hoping to get a fresh install, but now when I search integrations it’s not listed. The Wall Connector and PowerWall are listed - but not the custom integration.
How can I find and reinstall it?
Thanks for your help. I’ve been playing with Hubitat and SmartThings long enough that I can figure most things out. But Home Assistant is still several floors above my head!
Do you use hacs? It is the easiest way to install.
I have HACS installed. I’m not sure if I’ve used it. How can I find the Tesla integration using it?
Thanks very much.
Stan
Thanks for your help! Greatly appreciated.
Still suffering. I’ve gone through all the steps. All seems fine until Add Integration. I then get this:
It doesn’t show in Integrations, and all of the data is old, old, old. (Using SharpTools dashboard.)
(Speaking of old, old, old - I’m 88; maybe that’s the problem.)
I’ll continue playing with it. I have restarted HA when required, and cleared the browser’s cache.
Did you figure it out?
Never figured it out. Wish I had! I finally removed it from my dashboard.
Works perfectly here. Have you asked in github.
