Tesla Wall Connector Gen 3 RESTful
I got my Tesla Wall Connector Gen 3 yesterday and wanted to integrate this with HA, did not find any integration so I started to find a way and just wanted to share how i did this. Probably there is better ways and deeper way of doing this then please let me know below, I’m just a newbie :smiley:
I want four things when it comes to Tesla Wall Connector and these are:
  • See if a vehicle are connected to the charger :white_check_mark:
  • Be able to get how much energy last charging session was :white_check_mark:
  • Be able to control how much Amp the charger is giving to the vehicle
  • Be able to turn on/off the charging capabilities
I managed to get two out of four done yesterday and will instigate future how to solve all my asks. There is a API that is undocumented so it’s a bit like finding a needle in the haystack but below is some API calls:
  • http://>IP address</api/1/vitals
  • http://>IP address</api/1/wifi_status
  • http://>IP address</api/1/lifetime
  • http://>IP address</api/1/version
  • http://>IP address</tedapi/v1
The one I think is the most useful are the first one Vitals, so I created one sensor and one binary sensor. The sensor display how much energy Wh used by the last charging session and the binary sensor display if a vehicle is connected or not.
#Tesla Wall Connector Gen 3
rest:
  - authentication: basic
    username: ""
    password: ""
    scan_interval: 60
    resource: http://>IP address</api/1/vitals
      - name: "Last charge session"
        value_template: "{{ value_json.session_energy_wh }}"
        device_class: energy
    binary_sensor:
      - name: "Vehicle connected"
        value_template: "{{ value_json.vehicle_connected }}"
        device_class: occupancy
If you like to make a Tesla Wall Connector sensor with all Vitals attributs you can use the following code
rest:
    username: ""
    password: ""
    scan_interval: 60
      - name: "Tesla Wall Connector"
        value_template: "OK"
        json_attributes:
          - "contactor_closed"
          - "vehicle_connected"
          - "session_s"
          - "grid_v"
          - "grid_hz"
          - "vehicle_current_a"
          - "currentA_a"
          - "currentB_a"
          - "currentC_a"
          - "voltageA_v"
          - "voltageB_v"
          - "voltageC_v"
          - "relay_coil_v"
          - "pcba_temp_c"
          - "handle_temp_c"
          - "mcu_temp_c"
          - "uptime_s"
          - "input_thermopile_uv"
          - "prox_v"
          - "pilot_high_v"
          - "pilot_low_v"
          - "session_energy_wh"
          - "config_status"
          - "evse_state"
          - "current_alerts"
ps.
Don’t forget to change >IP address< to whatever IP address your Tesla Wall Connector has.
Hi!
I would also like to be able to change the Amps as this would solve a load balance issue I have :slight_smile:
Have you come any further with this?
Leaving a comment for subscription. Have any further APIs been discovered? I also have the Use case of setting Amps remotely. Would like to contribute also. How did you reverse engineer the APIs?
Sorry to say I have not, I have tried to Wireshark the communication but have not been successful to find out more :frowning: I also tried to look into the firmware but I’m not a hacker and it seams to encrypted.
I found one more API call:
  • http:///api/1/lifetime
It’s harder to find the way how to send Amps and on/off as it’s a POST command, so we need to figure out how the amps are formatted and where to send the info. It’s just a matter of testing back and forth to try to find the say, getting into the head of the engineering’s that built the API.
Hi ,
Do you plan to make a Git out all these data so we can have a “reference manual”
I have not a plan for this, if you like go ahead :slight_smile:
Great information. Is somebody already doing an integration based on this API-call data. Neat that there is serial number for HA unique ID too.
Just adding information about TWC from pi-hole, TWC gen3 seems to talk to “maestro-prd.sn.tesla.services” DNS-name… Then it also queries pool.ntp.org for time sync.
I saw that there is a new firmware but my charger did not auto update so I needed to do it manually. You can go to http://IP-of-charger/service and manually update the FW. After this you have power sharing as an option but to enable power sharing one would need add a second wall connecters and I don’t have that :frowning: So if one have two and can do some Wireshark between these two it would be nice!
Full Tesla Wall Charger gen 3 API taken into home assistant via configuration.yaml
rest:
    username: ""
    password: ""
    scan_interval: 600
    resource: http://192.168.9.129/api/1/vitals
      - name: "TWC session"
        value_template: "{{ value_json.session_s | int }}"
        unit_of_measurement: s
      - name: "TWC grid voltage"
        value_template: "{{ float(value_json.grid_v) }}"
        unit_of_measurement: V
        device_class: voltage
      - name: "TWC grid frequency"
        value_template: "{{ float(value_json.grid_hz) }}"
        unit_of_measurement: Hz
      - name: "TWC vehicle current"
        value_template: "{{ float(value_json.vehicle_current_a) }}"
        device_class: current
        unit_of_measurement: A
      - name: "TWC current A"
        value_template: "{{ float(value_json.currentA_a) }}"
      - name: "TWC current B"
        value_template: "{{ float(value_json.currentB_a) }}"
      - name: "TWC current C"
        value_template: "{{ float(value_json.currentC_a) }}"
      - name: "TWC current N"
        value_template: "{{ float(value_json.currentN_a) }}"
      - name: "TWC voltage A"
        value_template: "{{ float(value_json.voltageA_v) }}"
      - name: "TWC voltage B"
        value_template: "{{ float(value_json.voltageB_v) }}"
      - name: "TWC voltage C"
        value_template: "{{ float(value_json.voltageC_v) }}"
      - name: "TWC relay coil"
        value_template: "{{ float(value_json.relay_coil_v) }}"
      - name: "TWC pcba temp"
        value_template: "{{ float(value_json.pcba_temp_c) }}"
        device_class: temperature
        unit_of_measurement: C
      - name: "TWC handle temp"
        value_template: "{{ float(value_json.handle_temp_c) }}"
      - name: "TWC mcu temp"
        value_template: "{{ float(value_json.mcu_temp_c) }}"
      - name: "TWC uptime"
        value_template: "{{ value_json.uptime_s | int }}"
      - name: "TWC input thermopile uv"
        value_template: "{{ value_json.input_thermopile_uv | int }}"
      - name: "TWC prox"
        value_template: "{{ value_json.prox_v | int }}"
      - name: "TWC pilot high"
        value_template: "{{ float(value_json.pilot_high_v) }}"
      - name: "TWC pilot low"
        value_template: "{{ float(value_json.pilot_low_v) }}"
      - name: "TWC session energy"
        value_template: "{{ float(value_json.session_energy_wh) | multiply(0.001) | round(3) }}"
        unit_of_measurement: kWh
      - name: "TWC config status"
        value_template: "{{ value_json.config_status }}"
      - name: "TWC evse state"
        value_template: "{{ value_json.evse_state }}"
      - name: "TWC current alerts"
        value_template: "{{ value_json.current_alerts }}"
      - name: "TWC charging power A"
        value_template: "{{ float(value_json.voltageA_v) * float(value_json.currentA_a) | round(0) }}"
        device_class: power
        unit_of_measurement: W
      - name: "TWC charging power B"
        value_template: "{{ float(value_json.voltageB_v) * float(value_json.currentB_a) | round(0) }}"
        device_class: power
      - name: "TWC charging power C"
        value_template: "{{ float(value_json.voltageC_v) * float(value_json.currentC_a) | round(0) }}"
        device_class: power
      - name: "TWC total charging power"
        value_template: "{{ float(value_json.voltageA_v) * float(value_json.currentA_a) + float(value_json.voltageB_v) * float(value_json.currentB_a) + float(value_json.voltageC_v) * float(value_json.currentC_a) | round(0) }}"
        device_class: power
      - name: "TWC uptime str"
        value_template: "{{ '{:d} days {:02d}:{:02d}:{:02d}'.format(value_json.uptime_s // 86400, (value_json.uptime_s % 86400) // 3600, (value_json.uptime_s % 3600) // 60, (value_json.uptime_s % 3600) % 60) }}"
      - name: "TWC session str"
        value_template: "{{ '{:d} days {:02d}:{:02d}:{:02d}'.format(value_json.session_s // 86400, (value_json.session_s % 86400) // 3600, (value_json.session_s % 3600) // 60, (value_json.session_s % 3600) % 60) }}"
    binary_sensor:
      - name: "TWC contactor closed"
        value_template: "{{ value_json.contactor_closed }}"
        device_class: opening
      - name: "TWC vehicle connected"
        device_class: plug
    username: ""
    password: ""
    scan_interval: 600
    resource: http://192.168.9.129/api/1/lifetime
      - name: "TWC lifetime contactor cycles"
        value_template: "{{ value_json.contactor_cycles | int }}"
      - name: "TWC lifetime contactor cycles loaded"
        value_template: "{{ value_json.contactor_cycles_loaded | int }}"
      - name: "TWC lifetime alert count"
        value_template: "{{ value_json.alert_count | int }}"
      - name: "TWC lifetime thermal foldbacks"
        value_template: "{{ value_json.thermal_foldbacks | int }}"
      - name: "TWC lifetime avg startup temp"
        value_template: "{{ float(value_json.avg_startup_temp) }}"
      - name: "TWC lifetime charge starts"
        value_template: "{{ value_json.charge_starts | int }}"
      - name: "TWC lifetime energy kWh"
        value_template: "{{ value_json.energy_wh | multiply(0.001) | float(3) }}"
      - name: "TWC lifetime connector cycles"
        value_template: "{{ value_json.connector_cycles | int }}"
      - name: "TWC lifetime uptime"
      - name: "TWC lifetime charging time"
        value_template: "{{ value_json.charging_time_s | int }}"
      - name: "TWC lifetime uptime str"
      - name: "TWC lifetime charging time str"
        value_template: "{{ '{:d} days {:02d}:{:02d}:{:02d}'.format(value_json.charging_time_s // 86400, (value_json.charging_time_s % 86400) // 3600, (value_json.charging_time_s % 3600) // 60, (value_json.uptime_s % 3600) % 60) }}"
    username: ""
    password: ""
    scan_interval: 3600
    resource: http://192.168.9.129/api/1/version
      - name: "TWC firmware version"
        value_template: "{{ value_json.firmware_version }}"
      - name: "TWC part number"
        value_template: "{{ value_json.part_number }}"
      - name: "TWC serial number"
        value_template: "{{ value_json.serial_number }}"
    username: ""
    password: ""
    scan_interval: 600
    resource: http://192.168.9.129/api/1/wifi_status
      - name: "TWC wifi signal strength"
        value_template: "{{ value_json.wifi_signal_strength | int }}"
        device_class: signal_strength
        unit_of_measurement: dBm
      - name: "TWC wifi rssi"
        value_template: "{{ value_json.wifi_rssi | int }}"
      - name: "TWC wifi snr"
        value_template: "{{ value_json.wifi_snr | int }}"
      - name: "TWC wifi infra ip"
        value_template: "{{ value_json.wifi_infra_ip }}"
      - name: "TWC wifi mac"
        value_template: "{{ value_json.wifi_mac }}"
    binary_sensor:
      - name: "TWC wifi connected"
        value_template: "{{ value_json.wifi_connected }}"
        device_class: connectivity
      - name: "TWC internet"
        value_template: "{{ value_json.internet }}"
Other potential API directories and calls from firmware file…
/access
/alerts
/fwupdate
/installation
/service
/sharing, /sharing/add, /sharing/settings
/wifi
I updated to 21.29.1 fw-version of TWC and unfortunately /api/1/lifetime -stopped working. So if that data is important for you (like it would be for me) don’t upgrade.
The fault is the TWC is producing illegal JSON, as ‘nan’ is not allowed but ‘NaN’ would be.
{“contactor_cycles”:31,“contactor_cycles_loaded”:0,“alert_count”:47,“thermal_foldbacks”:0,“avg_startup_temp”:nan,“charge_starts”:31,“energy_wh”:91853,“connector_cycles”:3,“uptime_s”:566863,“charging_time_s”:32498}
I fixed the template as first solution found, using template’s regex_findall_index. But maybe rest-api “value” could be read and replaced with regex ‘nan’ to ‘NaN’ and then forward this data to template which decodes JSON as previously. That would be better solution…
        value_template: '{{ value | regex_findall_index("contactor_cycles\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("contactor_cycles_loaded\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("alert_count\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("thermal_foldbacks\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("charge_starts\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("energy_wh\":\s*(\d+)") | multiply(0.001) | float(3) }}'
        value_template: '{{ value | regex_findall_index("connector_cycles\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("uptime_s\":\s*(\d+)") | int }}'
        value_template: '{{ value | regex_findall_index("charging_time_s\":\s*(\d+)") | int }}'
I have updated to the 21.29.1 and all call works.
I tried to access /sharing, /sharing/add, /sharing/settings and it briefly display a page but does not allow to modify anything.
The pages :
/access
/alerts
/fwupdate
/installation
give an error
but /service works
Wireshark and two devices are needed in deed for current control. When adding the slave units for power sharing, master needs to know the slave unit’s SSID and WIFI password.
However Wiresharking might be difficult, as the master is connecting to slave’s own hotspot. So the obvious way would be creating your own honeypot: RPI to advertise Tesla named Wifi, configure master TWC to connect RPI, record requests and start creating responses. Eventually it should be possible to figure out how master tries to limit slave current settings…
For time being this is too much work for me, but later. Better yet, if there is someone with more experience who is willing to dig into this :slight_smile:
Easier approach might be connecting to Tesla Wifi right after power on, and keep the connection on forever… This would require a dedicated RPi. My first try with Chrome’s developer mode and copy-as-cURL failed. At least Chrome could keep the configuration state active for over 15 mins (changed succesfully the current setting after "uptime_s":2872).
I saw that in version 4.1 one can alter the charge Amp’s so I guess it will be in the API soon:) I know it’s not taking care if one would charge a non Tesla or Tesla not own by the owner of the charger but for personal use it would be perfect to change the charge Amp via the API.
As @Klangen82 pointed out, Tesla app can control only Tesla cars. We have a non-Tesla so :slight_smile:
TWC gen 3 is currently the cheapest charger with fixed cable and DC-fault current measurement. And there is HW for current adjustment, so I want to use it.
I did a small try out with the TWC:
  1. I added a new SSID to my WIFI: TeslaWallConnector_001122, password must be 12 characters, with capital letters (numbers were not accepted by TWC)
  2. Rebooted TWC
  3. Started capture in LAN
  4. Joined to TWC’s own WIFI, with a laptop
  5. Selected Add second TWC
Capture did show just some mDNS messages (pcap -file here:
MDNS.pcapng - Google Drive ). To me it looks pretty much the same as in normal startup (mDNS sent to normal WIFI network).
The next step would be creating a Python script that sends back something similar, so that TWC believes it has found a friendly neighbour… What would be an easy way of creating random mDNS messages?
I’ve got an old version of the firmware, don’t want to manually update it so I’ve come up with my own command_line and template integration:
Add more template sensor/binary_sensor entries if you want to expand the sensor list - just pull the values from the sensor.twc_lifetime or sensor.twc_vitals sensor attributes as I have done with the mine.
The idea is that you dont want to be polling the endpoints separately for each value, but instead poll once to extract all the info into a single sensor w/attributes then split those out to separate sensors using template sensors.
  - platform: command_line
    name: "TWC lifetime"
    unit_of_measurement: "kWh"
    json_attributes:
      - contactor_cycles
      - contactor_cycles_loaded
      - alert_count
      - thermal_foldbacks
      - charge_starts
      - connector_cycles
      - uptime_s
      - charging_time_s
      - energy_wh
    command: "curl -s 'http://192.168.4.22/api/1/lifetime' | sed 's/:nan/:NaN/g'"
    value_template: "{{ value_json.energy_wh | multiply(0.001) | round(1) }}"
    unit_of_measurement: "A"
    json_attributes:
      - contactor_closed
      - vehicle_connected
      - session_s
      - grid_v
      - grid_hz
      - vehicle_current_a
      - currentA_a
      - currentB_a
      - currentC_a
      - currentN_a
      - voltageA_v
      - voltageB_v
      - voltageC_v
      - relay_coil_v
      - pcba_temp_c
      - handle_temp_c
      - mcu_temp_c
      - uptime_s
      - input_thermopile_uv
      - prox_v
      - pilot_high_v
      - pilot_low_v
      - session_energy_wh
      - config_status
      - evse_state
    command: "curl -s 'http://192.168.4.22/api/1/vitals' | sed 's/:nan/:NaN/g'"
    value_template: "{{ value_json.vehicle_current_a | round(1) }}"
  - platform: statistics
    entity_id: sensor.twc_lifetime
template:
  - sensor:
      - name: "TWC Delivery Current"
        state: >
          {{ state_attr('sensor.twc_vitals', 'vehicle_current_a') }}
      - name: "TWC Delivery Power"
        unit_of_measurement: "kW"
        device_class: power
        state: >
          {{ (state_attr('sensor.twc_vitals', 'vehicle_current_a') * state_attr('sensor.twc_vitals', 'voltageA_v')) | multiply(0.001) | round(1) }}
      - name: "TWC Session kWh"
        state: >
          {{ state_attr('sensor.twc_vitals', 'session_energy_wh') | multiply(0.001) | round(1) }}
      - name: "TWC Handle Temperature"
        unit_of_measurement: "°C"
        state: >
          {{ state_attr('sensor.twc_vitals', 'handle_temp_c') }}
      - name: "TWC MCU Temperature"
        state: >
          {{ state_attr('sensor.twc_vitals', 'mcu_temp_c') }}
      - name: "TWC PCBA Temperature"
        state: >
          {{ state_attr('sensor.twc_vitals', 'pcba_temp_c') }}
  - binary_sensor:
      - name: "TWC Vehicle Charging"
        device_class: battery_charging
        state: >
          {{ is_state_attr('sensor.twc_vitals', 'contactor_closed', true) }}
      - name: "TWC Vehicle Connected"
        state: >
          {{ is_state_attr('sensor.twc_vitals', 'vehicle_connected', true) }}
homeassistant:
  customize:
    sensor.twc_lifetime:
      state_class: total_increasing
Just to let people know on this thread that there is a Gen 3 integration coming with the 2021.12 release:
I tested it but it will no connect to my wall connector :frowning: I can access the web interface from my laptop and from HA.
Perhaps raise a bug report on GitHub?
Done Can add the Tesla Wall Connector but not able to get any data · Issue #61150 · home-assistant/core · GitHub
