I’m running https://github.com/maddox/harmony-api in docker and all I need is a config to connect to my mosquito. No auth for Harmony. It seems to update my input select and issue commands much faster than this component, but I’ll keep testing.
Yes, I have tried as third hub, but it causes HASS to stall and not make it to user interface web page.
great to hear, and you arent kidding!
can you enable debugging for the remote component to see where it’s stalling at?
it’s going to be faster, it’s keeping an open link and receiving push notifications instead of pulling. I’m not quite sure how to implement that in python yet, my java skills arent good enough to understand the code fully
Troubleshooting my Harmony Link (my Hamony Hubs are working!)
set the following in configuration.yaml for testing:
logger:
default: debug
logs:
homeassistant.components.remote: debug
frontend:
discovery:
remote:
platform: harmony
username: [email protected]
password: 123456
host: 192.168.1.17
port: 5222
activity: Deck iTunes
history:
logbook:
Not seeing much in home-assistant.log:
16-11-23 14:25:53 homeassistant.loader: Loaded remote.harmony from homeassistant.components.remote.harmony
16-11-23 14:25:53 homeassistant.bootstrap: Setting up remote
16-11-23 14:25:53 homeassistant.components.remote: Setting up remote.harmony
16-11-23 14:25:53 homeassistant.components.remote.harmony: Loading Harmony component: Rec Room
Ok managed to get more info in the home-assistant.log
16-11-23 14:44:30 homeassistant.loader: Loaded remote.harmony from homeassistant.components.remote.harmony
16-11-23 14:44:30 homeassistant.bootstrap: Setting up remote
16-11-23 14:44:30 homeassistant.components.remote: Setting up remote.harmony
16-11-23 14:44:30 homeassistant.components.remote.harmony: Loading Harmony component: Rec Room
16-11-23 14:44:30 homeassistant.components.remote: Error while setting up platform harmony
File "C:\Program Files (x86)\Python35-32\lib\site-packages\homeassistant\helpers\entity_component.py", line 150, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "C:\Program Files (x86)\Python35-32\lib\asyncio\futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "C:\Program Files (x86)\Python35-32\lib\asyncio\tasks.py", line 296, in _wakeup
future.result()
File "C:\Program Files (x86)\Python35-32\lib\asyncio\futures.py", line 274, in result
raise self._exception
File "C:\Program Files (x86)\Python35-32\lib\concurrent\futures\thread.py", line 55, in run
File "C:\Program Files (x86)\Python35-32\lib\site-packages\homeassistant\components\remote\harmony.py", line 47, in setup_platform
config.get(CONF_PASSWORD))
File "C:\Program Files (x86)\Python35-32\lib\site-packages\pyharmony\__main__.py", line 72, in ha_get_token
token = harmony_auth.login(username, password)
File "C:\Program Files (x86)\Python35-32\lib\site-packages\pyharmony\auth.py", line 46, in login
id_token = resp_dict['id_token']
TypeError: 'int' object is not subscriptable
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_off, domain=remote>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_on, domain=remote>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=send_command, domain=remote>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=sync, domain=remote>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=remote>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up http
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=http>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up api
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=api>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up frontend
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=frontend>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up history
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=history>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up discovery
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=discovery>
16-11-23 14:44:30 homeassistant.bootstrap: Setting up logbook
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=logbook>
16-11-23 14:44:30 homeassistant.core: Starting Home Assistant core loop
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
16-11-23 14:44:30 homeassistant.core: Bus:Handling <Event homeassistant_start[L]>
16-11-23 14:44:30 homeassistant.core: Timer:starting
16-11-23 14:44:30 netdisco.service: Scanning
16-11-23 14:44:30 homeassistant.components.recorder: Ended unfinished session (id=34 from 2016-11-23 19:41:31.110761)
16-11-23 14:44:30 homeassistant.components.recorder: Found unfinished sessions
16-11-23 14:44:33 homeassistant.components.http: Serving / to 192.168.1.19 (auth: True)
16-11-23 14:44:34 homeassistant.components.http: Serving /api/bootstrap to 192.168.1.19 (auth: True)
16-11-23 14:44:35 homeassistant.components.http: Serving /api/stream to 192.168.1.19 (auth: True)
Can somebody explain what I’m doing wrong? I get this error:
16-11-23 21:17:01 homeassistant.bootstrap: Invalid config for [script]: expected a dictionary for dictionary value @ data[‘script’]. Got [OrderedDict([(‘service’, ‘remote.turn_on’), (‘entity_id’, ‘remote.hburner’), (‘data’, OrderedDict([(‘activity’, ‘22491566’)]))])]. (See /root/.homeassistant/configuration.yaml:762). Please check the docs at https://home-assistant.io/components/script/
My config is:
script:
- service: remote.turn_on
entity_id: remote.hburner
activity: "22491566"
Tried this config
762 script:
763 service: remote.turn_on
764 entity_id: remote.hburner
765 data:
766 activity: "22491566"
762 script:
763 - service: remote.turn_on
765 data:
Now I get:
16-11-23 21:29:21 ERROR (Thread-1) [homeassistant.util.yaml] mapping values are not allowed here
in “/root/.homeassistant/configuration.yaml”, line 764, column 16
EDIT: nevermind, I’m dumb. Moved everything to an automation block, selected by an info_select. Works like a charm.
I’ve now had to disable the remote component as I cannot start HASS with it enabled. It just freezes at:
16-11-25 18:37:34 INFO (Thread-5) [homeassistant.components.remote.harmony] Loading Harmony component: Family Room
This is with 0.33.2 as 0.33.3 is completely borked on my system. Havn’t tried 0.33.4 yet but the list of changes doesn’t make me especially hopeful.
it looks like the authenticaton is failing. What version of pyharmony are you running?
what version did you start noticing issues with? I’m running 0.32.4 on my production vm and 0.34.0 on my dev vm
I am using 1.0.11. Working for hubs but not link.
May not be worth your time to support link.
Pyharmony has been updated to 1.0.12, the first step in authenticating to Logitech’s servers is no longer need, this should speed startup time.
My dev branch has the updated code as well as fixes suggested by @balloob, I’d appreciate if you guys could give it a shot and let me know how it goes
What is the easiest way to upgrade the module?
In my environment, I was able to upgrade it using pip3 install --upgrade pyharmony
As was I. Worst case scenario, you can download the tar from https://pypi.python.org/pypi/pyharmony/1.0.12 and install it manually.
After I had some issues earlier on with this, I decided to start from scratch again.
I reinstalled the AIO version on my RPi.
Then just copied the remote directory from your git and all was fine.
svn export https://github.com/iandday/home-assistant/trunk/homeassistant/components/remote
cp -TRv ./remote /srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/remote
Thanks a lot
Hi iandday, unfortunately the new 1.0.12 is not working for me.
All is working when I revert to 1.0.11.
I am on windows 10, hass v0.33.4.
Here is the debug log:
16-11-29 22:23:12 homeassistant.loader: Loaded remote.harmony from homeassistant.components.remote.harmony
16-11-29 22:23:12 homeassistant.bootstrap: Setting up remote
16-11-29 22:23:12 homeassistant.components.remote: Setting up remote.harmony
16-11-29 22:23:12 sleekxmpp.xmlstream.resolver: Could not find dnspython package. Not all features will be available
16-11-29 22:23:12 homeassistant.components.remote.harmony: Loading Harmony platform: Bedroom
16-11-29 22:23:12 homeassistant.components.remote.harmony: Loading Harmony platform: Basement
16-11-29 22:23:12 homeassistant.components.remote.harmony: calling pyharmony.ha_get_token with username: [email protected] and password: password
16-11-29 22:23:12 homeassistant.components.remote.harmony: invalid literal for int() with base 10: 'password' for remote: Bedroom
16-11-29 22:23:12 homeassistant.components.remote.harmony: invalid literal for int() with base 10: 'password' for remote: Basement
16-11-29 22:23:12 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=remote, service=turn_off>
16-11-29 22:23:12 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=remote, service=turn_on>
16-11-29 22:23:12 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=remote, service=send_command>
16-11-29 22:23:12 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=remote, service=sync>
16-11-29 22:23:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=remote>
thanks for including the logs, thats very helpful!
version 1.0.12 includes the new local authentication only routine, you no longer need to supply your logitech account information. When you upgrade the pyharmony version youll also need to upgrade the remote directory in my fork.
Once you’ve upgraded both components you can remove the username and password lines from the remote portion of your config yaml file
Ok, I updated the remote component from your fork, deletd my harmony username and password, all is working with 1.0.12!
Thank you for the great component.
