Hello there!
I am working on an Integration for the (common?) weather station “TFA KlimaLogg_pro”.
My work is based on a weex-module, which was converted to be used “stand alone” as a PyPi-Module (name: kloggpro):
To get all this into Home Assistant, i have created a cusom component:
It is still experimental, but the prototype works for me™
The kloggpro-module still outputs many debug information, the custom component can only add temperature-sensors. “Host” will be the UI-name of this device, if you add it to Home Assistant.
Maybe someone who owns one of this stations wants to try this integration? There will be many errors… but I am working on it
