No matter which assistant I use, I get the error “This assistant cannot control your home” when I choose the Assist icon from the dashboard. I can type but the send button wont work. However, when I open the debug tool and start a debug run, it works fine. I’ve looked around but haven’t found any posts about this issue. Does anyone have a fix?
Hard to comment without more details. Have you got a Home Assistant Cloud account? Have you exposed entities to Assist? What’s your HA setup?
Edit: Having said that, someone else has the same problem:
No home assisant (nabu casa) cloud. It’s all local. except I’m using gpt4o-mini as conversation agent.
As I speak french to my assistant and get FAR better results with it, I’m using vosk as STT
piper as STT.
as you can see, when I do use it using the mobile app, the assistants appears (see above post).
here is the result when I’m using my voice assistant using my home assistant mobile app, it’s all fine :
No, it looks like there is some kind of bug that appeared with version 2024.8.x, as everything was working right from my webui’s beforehand.
Yes I have a home assistant cloud account and its active. Entities have been exposed. I have been away from home for a few days but it seems to just randomly start working. It’s not very consistent at all I’m running 2024.8.0. I moved and just now getting back into using home assistant so its a fresh install and only a few integrations. I will read the other issue and see if that helps!
YES! The mobile app works fine! I hope the web version starts working soon. I’m still setting up my new home assistant and prefer testing everything from a browser.
