Here)
try
ha dns options --servers dns://1.1.1.1
ha dns restart
network info
and post the results again
And ? Did it work ?
you are the best!!! thank you very much it helped))
Hi Francis, just a few questions out of curiosity.
- Since he had this issue on all virtual platforms: is that because something is/was off with his Windows regarding networking?
- I just tested this on my non-production HAOS which has static network settings but it keeps the DNS server that was configured before, even after restarting the instance.
I guess this is not normal behavior, right?
ps: the last command
network info
misses ha
in front (in case someone bumps on this post), no?
It is complicated.
You have the dns server that supervisor uses, that is a container named hassio_dns
and you have the dns that is used inside the HA container
changes the dns of the hassio_dns container, but not the dns of the HA container.
Thanks for explaining!
Was all this because during the setup of HA the settings of the underlying OS (Windows in his case) was taken?
Always the question with DNS problems, where is the problem located ? That is why well-known DNS-servers as 1.1.1.1 (Cloudflare) or 8.8.8.8 (Google) are often a solution.
Of course it quite often DNS, but does the setup take the DNS server from the underlying OS, or not? (I guess it would work that way)
Normally from the DHCP-server
hello francis, could you help me with one more problem) I canβt install Add-ons at all, hereβs the message (Failed to install add-on
βAddonManager.installβ blocked from execution, no host internet connection)
Try to disable ipv6
please can you tell me where? And How?
settings β system β network
disabled) rebooted HA but the error remained
in the console, what does
curl http://version.home-assistant.io/online.txt
return ?
NetworkManager is online
Iβm running out of ideas
try
date --set="YYYY-MM-DD HH:MM"
ha network reload
replace YYYY-MM-DD HH:MM with current time
changed it but didnβt help)
