That is in train.
This, and very much this!
Iām wondering if itās worth continuing with Home Assistant if my configuration API is disappearingā¦
Keep up the great work.
I like the new front end and cleaner yaml files.
Helpers are awesome.
Now with more tasmota auto discovery options for sensors and switches it makes things even faster to integrate new devices.
For those of you who are frustrated by this decision:
It seems a bit hard to change the decision that has been made and the owners of the repository can (unfortunately) take such decision. Thereās a bit of evil on the good, and a bit of good in the evil.
Like many of you, I have also expressed my opinion on why I do not think this is the right decision from an Open Source perspective. Although many of you have articulated the reasons for which is a bad decision much better here.
However, my question would be: when the decision is implemented, what can we do? I have some ideas and I will be sharing some of them soon both focused on users and developers. I would love to read some of your ideas too.
From your twatter thread
Personally, Iāve taken down 2 published components, removed HACS support for one of them and cancelled other plans for components that I was building for home_assistant and their HACS support.
Childish? Yes
And what have you got against HACS?
Apparently HACS is an official custom integration.
Itās not.
My first idea was to completely remove the integrations, which I did consider and did with some of them.
I finally decided that having to copy the code was better than install it from a UI. Itās kind of the opposite of what was decided on this blog post to force people to use UI for official integrations.
Thanks for sharing your opinion. You can read my previous message on why I want things to be installed only via code rather than via UI only.
(Actually, I would prefer both, but then the official integrations only offer one of them).
Removing your custom components from HACS is unrelated to this issue. Anything on HACS is installable via command line.
Also custom components do not have to be configurable by UI. They can stick to yaml. They wonāt ever make it to core, but that is not the point.
To be very clear, this thread is about the deprecation of core integrations to be configured by yaml.
It was not me who brought it up and I agree. Letās focus on Home-Assistant to not support YAML on new integrations.
Yes you did, you said you were removing HACS support as protest about partial yaml deprecation.
I linked Twitter with my opinion. 99% on that tweet is about why I think deprecating YAML on official integrations is a bad decision and powered by NabuCasa interests. From that tweet, you cherry picked the part about me deprecating HACS and, instead of replying on Twitter, copied that fragment to this post.
In any case, can we focus on the topic at hand around the deprecation of YAML for new integrations? (and probably in the past ones at some point, since you cannot also make changes to the YAML config and if the spec changes, YAML configuration would no longer work).
It has been discussed to death. The decision is done, for better or worse, so your protests, like the others (including me), will fall on deaf ears.
Given that it is a done deal, either you want to work with home assistant or you donāt. If you donāt, then I suggest you get an interest in procreation and travel.
That was a smooth change in topic, but at least back to the original and āproductiveā one
Yet, youāre still replying and replying to my posts. If you really do not care, there is no need for you to engage. You do not need to reply. It would best for both
If you are wrong and someone cares, they will engage. If you are right and no one cares, then thereās nothing for you to worry.
I think there are more options than this. My post was asking and trying to be productive on that:
I do have some ideas and I am working on a small post that I will be sharing when ready. I hope those who care will engage, but so far Iāve only encountered people deviating from productive conversations or even from the main purpose of this conversation.
For those interested in the ācost of maintenanceā, this is how much it took me to add support to the PS4 component:
Config = collections.namedtuple(
'Config', f'{const.CONF_ENTRY_ID} {const.CONF_DATA}')
async def async_setup_platform(
hass, config, async_add_entities, discovery_info=None):
"""Loads configuration and delegates to official integration."""
# Load configuration.yaml
host = config.get(const.CONF_HOST)
name = config.get(const.CONF_NAME, const.DEFAULT_NAME)
region = config.get(const.CONF_REGION)
token = config.get(const.CONF_TOKEN)
# Format it in the new config_entry JSON format.
config_entry = Config(
util.slugify(name),
const.CONF_TOKEN: token,
const.CONF_DEVICES: [
const.CONF_HOST: host,
const.CONF_NAME: name,
const.CONF_REGION: region,
await ps4_media_player.async_setup_entry(
hass, config_entry, async_add_entities)
return True
Although, of course, this assumes you already have the token. However, the same config_flow
could provide that for you to configure as many other components do. I will be publishing a full example when completed.
It might work but its not an acceptable implementation since you go to async_setup_entry directly
Can you explain further on whatās wrong with it and/or how to fix it?
Do note that the full code is not here, I am working on a component based on this. However, happy to tackle any issues that there might exist.
You need to create a config entry in order to use async_setup_entry. You need to create a config flow with an import step that can be called in async_setup
I do not think so.
works with configuration.yaml
and does not require that. Do note that ps4_media_player.async_setup_entry
is the core ps4 component. However, this all just python functions and classes, and you can pass your own configuration instead of rely on Home-Assistant.
Yes, to keep the original flow with async_setup_entry
, I need to have the config flow. A few notes:
- If that code was added to the original repository, the rest of function falls into place.
- The purpose of this code is a
custom_component
that addsconfiguration.yaml
, so not having support for the UI wouldnāt be a problem. If thatās what you want, the core component is your option. - Now, I was able to support both. As I said, the code is not complete, but you can add support like this:
@config_entries.HANDLERS.register(const.DOMAIN)
class PlayStation4FlowHandler(config_flow.PlayStation4FlowHandler):
def __init__(self):
super().__init__()
It might work but Iām telling you its a requirement. Config entry to use async_setup_entry. I donāt see arguing for it working in a thread that is focusing on official content. You can do whatever you like with custom components
