The Pick Me Up
We live in an apartment building with two entry gates. To be let in you need to push a button on each gate, which calls our in-apartment telephone. We pick it up and push a button to let someone in. We have to do this twice, for both gates. This has now been automated, thanks to Home Assistant and ESPHome.
I have created a 3D-printed wall attachment, which holds two servos and a microphone. It’s all connected to an ESP32 and it works like this:
  • The phone rings when someone pushes the button outside. The microphone detects this ringtone
  • The pick-up-servo lifts the receiver.
  • The other servo pushes the “open door”- button
It then lets go of the button and hangs up the receiver - and moves out of the way so you can also pick up the phone manually if you want to. I have an input boolean I can activate, which turns automatic answering on or off. Normally I have set it to just send an actionable notification to my phone when the phone rings, with an option to open the gate from there.
Video here:
https://www.youtube.com/watch?v=eGmKvuyp2_s
STLs here:
https://www.thingiverse.com/thing:4691370
ESPHome config:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: "YOURSSID"
  password: "YOURPASSWORD"
  ap:
    ssid: "Esp Door Opener Fallback Hotspot"
    password: "PSWD"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    - service: control_lift_servo
      variables:
        level: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
    - service: control_button_servo
      variables:
        level: float
      then:
        - servo.write:
    - service: detach_lift_servo
      then:
        - servo.detach:
    - service: detach_button_servo
      then:
        - servo.detach:
ota:
output:
  - platform: ledc
    pin: 27
    frequency: 50 Hz
  - platform: ledc
    pin: 25
    frequency: 50 Hz
servo:
  - id: lift_servo
    output: lift_servo_pin
  - id: button_servo
    output: button_servo_pin
binary_sensor:
  - platform: gpio
    pin: 32
    name: "Door Opener Microphone"
    device_class: sound
    filters:
      - invert:
I made a script to control the movements, and it is horrifyingly ugly, due to the fact that I don’t know how to make the servo slow down in other way than this. Any help here would be greatly appreciated!
open_door:
  alias: Lift reciever and push button
  sequence:
    - service: homeassistant.turn_on
        entity_id: script.raise_handle
    - delay:
        seconds: 3
        entity_id: script.push_button
    - delay:
        seconds: 5
        entity_id: script.lower_handle
    - delay:
        seconds: 5
    - service: esphome.esp_door_opener_detach_button_servo
    - service: esphome.esp_door_opener_detach_lift_servo
push_button:
  alias: Push Door Opener Button
  sequence:
    - service: esphome.esp_door_opener_control_button_servo
        level: 90
    - delay:
        seconds: 5
        level: 0
raise_handle:
  alias: Raise Handle
  sequence:
    - service: esphome.esp_door_opener_control_lift_servo
        level: 100
    - delay:
        milliseconds: 15
        level: 99
    - delay:
        milliseconds: 15
        level: 98
    - delay:
        milliseconds: 15
        level: 97
    - delay:
        milliseconds: 15
        level: 96
    - delay:
        milliseconds: 15
        level: 95
    - delay:
        milliseconds: 15
        level: 94
    - delay:
        milliseconds: 15
        level: 93
    - delay:
        milliseconds: 15
        level: 92
    - delay:
        milliseconds: 15
        level: 91
    - delay:
        milliseconds: 15
        level: 90
    - delay:
        milliseconds: 15
        level: 89
    - delay:
        milliseconds: 15
        level: 88
    - delay:
        milliseconds: 15
        level: 87
    - delay:
        milliseconds: 15
        level: 86
    - delay:
        milliseconds: 15
        level: 85
    - delay:
        milliseconds: 15
        level: 84
    - delay:
        milliseconds: 15
        level: 83
    - delay:
        milliseconds: 15
        level: 82
    - delay:
        milliseconds: 15
        level: 81
    - delay:
        milliseconds: 15
        level: 80
    - delay:
        milliseconds: 15
        level: 79
    - delay:
        milliseconds: 15
        level: 78
    - delay:
        milliseconds: 15
        level: 77
    - delay:
        milliseconds: 15
        level: 76
    - delay:
        milliseconds: 15
        level: 75
    - delay:
        milliseconds: 15
        level: 74
    - delay:
        milliseconds: 15
        level: 73
    - delay:
        milliseconds: 15
        level: 72
    - delay:
        milliseconds: 15
        level: 71
    - delay:
        milliseconds: 15
        level: 70
    - delay:
        milliseconds: 15
        level: 69
    - delay:
        milliseconds: 15
        level: 68
    - delay:
        milliseconds: 15
        level: 67
    - delay:
        milliseconds: 15
        level: 66
    - delay:
        milliseconds: 15
        level: 65
    - delay:
        milliseconds: 15
        level: 64
    - delay:
        milliseconds: 15
        level: 63
    - delay:
        milliseconds: 15
        level: 62
    - delay:
        milliseconds: 15
        level: 61
    - delay:
        milliseconds: 15
        level: 60
    - delay:
        milliseconds: 15
        level: 59
    - delay:
        milliseconds: 15
        level: 58
    - delay:
        milliseconds: 15
        level: 57
    - delay:
        milliseconds: 15
        level: 56
    - delay:
        milliseconds: 15
        level: 55
    - delay:
        milliseconds: 15
        level: 54
    - delay:
        milliseconds: 15
        level: 53
    - delay:
        milliseconds: 15
        level: 52
    - delay:
        milliseconds: 15
        level: 51
    - delay:
        milliseconds: 15
        level: 50
    - delay:
        milliseconds: 15
        level: 49
    - delay:
        milliseconds: 15
        level: 48
    - delay:
        milliseconds: 15
        level: 47
    - delay:
        milliseconds: 15
        level: 46
    - delay:
        milliseconds: 15
        level: 45
    - delay:
        milliseconds: 15
        level: 44
    - delay:
        milliseconds: 15
        level: 43
    - delay:
        milliseconds: 15
        level: 42
    - delay:
        milliseconds: 15
        level: 41
    - delay:
        milliseconds: 15
        level: 40
    - delay:
        milliseconds: 15
        level: 39
    - delay:
        milliseconds: 15
        level: 38
    - delay:
        milliseconds: 15
        level: 37
    - delay:
        milliseconds: 15
        level: 36
    - delay:
        milliseconds: 15
        level: 35
    - delay:
        milliseconds: 15
        level: 34
    - delay:
        milliseconds: 15
        level: 33
    - delay:
        milliseconds: 15
        level: 32
    - delay:
        milliseconds: 15
        level: 31
    - delay:
        milliseconds: 15
        level: 30
    - delay:
        milliseconds: 15
        level: 29
    - delay:
        milliseconds: 15
        level: 28
    - delay:
        milliseconds: 15
        level: 27
    - delay:
        milliseconds: 15
        level: 26
    - delay:
        milliseconds: 15
        level: 25
    - delay:
        milliseconds: 15
        level: 24
    - delay:
        milliseconds: 15
        level: 23
    - delay:
        milliseconds: 15
        level: 22
    - delay:
        milliseconds: 15
        level: 21
    - delay:
        milliseconds: 15
        level: 20
    - delay:
        milliseconds: 15
        level: 19
    - delay:
        milliseconds: 15
        level: 18
    - delay:
        milliseconds: 15
        level: 17
    - delay:
        milliseconds: 15
        level: 16
    - delay:
        milliseconds: 15
        level: 15
    - delay:
        milliseconds: 15
        level: 14
    - delay:
        milliseconds: 15
        level: 13
    - delay:
        milliseconds: 15
        level: 12
    - delay:
        milliseconds: 15
        level: 11
    - delay:
        milliseconds: 15
        level: 10
    - delay:
        milliseconds: 15
        level: 9
    - delay:
        milliseconds: 15
        level: 8
    - delay:
        milliseconds: 15
        level: 7
    - delay:
        milliseconds: 15
        level: 6
    - delay:
        milliseconds: 15
        level: 5
    - delay:
        milliseconds: 15
        level: 4
    - delay:
        milliseconds: 15
        level: 3
    - delay:
        milliseconds: 15
        level: 2
    - delay:
        milliseconds: 15
        level: 1
    - delay:
        milliseconds: 15
        level: 0
    - delay:
        milliseconds: 15
        level: -1
    - delay:
        milliseconds: 15
        level: -2
    - delay:
        milliseconds: 15
        level: -3
    - delay:
        milliseconds: 15
        level: -4
    - delay:
        milliseconds: 15
        level: -5
    - delay:
        milliseconds: 15
        level: -6
    - delay:
        milliseconds: 15
        level: -7
    - delay:
        milliseconds: 15
        level: -8
    - delay:
        milliseconds: 15
        level: -9
    - delay:
        milliseconds: 15
        level: -10
    - delay:
        milliseconds: 15
        level: -11
    - delay:
        milliseconds: 15
        level: -12
    - delay:
        milliseconds: 15
        level: -13
    - delay:
        milliseconds: 15
        level: -14
    - delay:
        milliseconds: 15
        level: -15
    - delay:
        milliseconds: 15
        level: -16
    - delay:
        milliseconds: 15
        level: -17
    - delay:
        milliseconds: 15
        level: -18
    - delay:
        milliseconds: 15
        level: -19
    - delay:
        milliseconds: 15
        level: -20
        level: -21
    - delay:
        milliseconds: 15
        level: -22
    - delay:
        milliseconds: 15
        level: -23
    - delay:
        milliseconds: 15
        level: -24
    - delay:
        milliseconds: 15
        level: -25
    - delay:
        milliseconds: 15
        level: -26
    - delay:
        milliseconds: 15
        level: -27
    - delay:
        milliseconds: 15
        level: -28
    - delay:
        milliseconds: 15
        level: -29
    - delay:
        milliseconds: 15
        level: -30
    - delay:
        milliseconds: 15
        level: -31
    - delay:
        milliseconds: 15
        level: -32
    - delay:
        milliseconds: 15
        level: -33
    - delay:
        milliseconds: 15
        level: -34
    - delay:
        milliseconds: 15
        level: -35
    - delay:
        milliseconds: 15
        level: -36
    - delay:
        milliseconds: 15
        level: -37
    - delay:
        milliseconds: 15
        level: -38
    - delay:
        milliseconds: 15
        level: -39
    - delay:
        milliseconds: 15
        level: -40
    - delay:
        milliseconds: 15
lower_handle:
# just reverse of the raise handle script
Here is the automation:
# Door opener ##
- alias: Enable ringing boolean
    - platform: state
      entity_id: binary_sensor.door_opener_microphone
      to: 'on'
  condition:
    condition: state
    entity_id: input_boolean.ringtone_detected
    state: 'off'
- alias: Disable ringing boolean
    - platform: state
      to: 'on'
    - delay:
        seconds: 15
    - service: homeassistant.turn_off
- alias: Door opener manual
    - platform: state
      to: 'on'
  condition:
    condition: state
    entity_id: input_boolean.auto_open_door
    state: 'off'
    - service: notify.mobile_app_my_mobil
        message: Someone is at the door downstairs
          actions:
            - action: OPEN_DOOR
              title: "Open the door"
          ttl: 0
          priority: high
- alias: Door opener automatic
    - platform: state
      to: 'on'
  condition:
    condition: state
    state: 'on'
        message: Someone is at the door downstairs, opening door automatically
          ttl: 0
          priority: high
      entity_id: script.open_door
- alias: Open the downstairs door
    platform: event
    event_type: mobile_app_notification_action
    event_data:
      action: OPEN_DOOR
Finally, the input booleans:
ringtone_detected:
  name: Door opener is ringing
  initial: off
  icon: mdi:phone-in-talk
auto_open_door:
  name: Open the door automatically when the bell rings
  initial: off
  icon: mdi:door-open
Cool!
I also had a similar system for the intercom, which looks to be the same, in my old apartment, where I also utilized servos😄 The GitHub repo for the project. Fun to see someone doing the same!
That looks very similar to our intercom! The difference may be that we can not push the “open door”-button unless the receiver is lifted up first, so we ended up needing two servos. Yours look good!
Awesome use of technology to bypass the security that your apartment building has in place to help keep out those who might do you or your neighbors harm. If something happens to one of your neighbors as a result of your device, I wonder how much they will ask for in the lawsuit.
Yikes! Yup, that could be a concern. I’m still the one letting people in or not though, just from my phone.
As long as you have that notification running. It’s the other side of that “Normally I have…” that I was speaking about. :slight_smile:
Very cool. Personally I would implement it a bit differently so that you’re not streaming commands from HA to the ESP with every command. You can import the bookend into your esphome confit and then use them to trigger scripts or automations that run locally on the device. But if the commands aren’t overloading the api then it might be ok. Only possible downside is if comms are lost mid command you might be stuck in an unknown state.
Really cool, wish I had a 3D printer.
I did a similar thing electrically without servos.
