The system cannot restart because the configuration is not valid
Hey all;
I am very new to HA and YAML. I get this error after I edited my configuration.yaml to add a template sensor.
“The system cannot restart because the configuration is not valid: Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 11). Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None.”
I added the below to my sensor.yaml and got a lot of errors. I read the topic HERE and thought I was having the same problems. So I didn’t change anything.
- plateform: template
  sensors:
    hallway_smoke_co_alarm:
      unique_id: hallway_smoke_co_alarm_status
      friendly_name: "Hallway Smoke & CO Detector Status"
      value_template: >-
        {% if is_state("sensor.hallway_smoke_detector_51_alarmlevel", "255") and is_state("sensor.hallway_smoke_detector_51_alarmtype", "1")%}
        !!!SMOKE DETECTED!!!
        {% elif is_state("sensor.hallway_smoke_detector_51_alarmlevel", "255") and is_state("sensor.hallway_smoke_detector_51_alarmtype", "2")%}
        !!!CARBON MONOXIDE ALARM!!!
        {% elif is_state("sensor.hallway_smoke_detector_51_alarmlevel", "0") and is_state("sensor.hallway_smoke_detector_51_alarmtype", "12")%}
        TEST TEST TEST
        {% elif is_state("sensor.hallway_smoke_detector_51_alarmlevel", "255") and is_state("sensor.hallway_smoke_detector_51_alarmtype", "13")%}
        Safe - Normal Operation
        {% else %}
        UNKOWN
        {% endif %}
      icon_template: >-
        mdi:fire
        mdi:cloud-outline
        mdi:alert-octagram
        mdi:smoke-detector
        {% endif %}
When I go to validate my config I get the above errors. Here is my configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensor.yaml
nest:
  client_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.apps.googleusercontent.com
  client_secret: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  # "Project ID" in the Device Access Console (not Cloud Project ID!)
  project_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
frontend:
  # your configuration.
  themes: !include_dir_merge_named themes
input_select:
  themes:
    icon: mdi:format-paint
    options:
      - Caule Black Rose
      - Caule Black Purple
      - Caule Black Blue
      - Caule Black Aqua
      - Caule Black Green
      - Caule Black Yellow
      - Caule Black Orange
      - Caule Black Coral
      - Caule Black Pink
      - Caule Black Gray
      - Caule Dark Rose
      - Caule Dark Purple
      - Caule Dark Blue
      - Caule Dark Aqua
      - Caule Dark Green
      - Caule Dark Yellow
      - Caule Dark Orange
      - Caule Dark Coral
      - Caule Dark Pink
      - Caule Dark Gray
      - Caule Light Rose
      - Caule Light Purple
      - Caule Light Blue
      - Caule Light Aqua
      - Caule Light Green
      - Caule Light Yellow
      - Caule Light Orange
      - Caule Light Coral
      - Caule Light Pink
      - Caule Light Gray
      - Caule Black Rose Glass
      - Caule Black Purple Glass
      - Caule Black Blue Glass
      - Caule Black Aqua Glass
      - Caule Black Green Glass
      - Caule Black Yellow Glass
      - Caule Black Orange Glass
      - Caule Black Coral Glass
      - Caule Black Pink Glass
      - Caule Black Gray Glass
      - Default
camera:
  - platform: generic
    still_image_url: https://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?num=20&type=N0Q&mapx=400&mapy=240&brand=wui&delay=15&frame=0&scale=0.75&transx=0&transy=0&severe=1&smooth=1&centerx=400&centery=240&station=LSX&rainsnow=1&lightning=1&noclutter=1&showlabels=0&showstorms=10&rand=27422459
What am I doing wrong?
You misspelled platform:
Also you can ignore the “property is not allowed” warnings. That is a bug in the home assistant helper extension.
I fixed the misspelling of ‘platform’ I go to validate my config ang get the below error.
‘Invalid config for [sensor.template]: [sensor] is an invalid option for [sensor.template]. Check: sensor.template->sensor. (See ?, line ?)’
Thank you. Finally got it fixed.
