Hi all,
In a past project (How I added a Hayward solar pool control to HA via ESPhome) I basically tapped into an existing setup with thermistors so I could add the temperature of my pool in HA.
I’m now working on a new and upgraded setup in which I basically want to replace that solar controller with a different setup based on an ESP32-S3 and reuse those same thermistors. The board I already have (I’m using this one: WAVESHARE-6CH-RELAY | devices.esphome.io because of the multiple relays and RS-485 - there isn’t a fritzing for it but the concept is the same).
So I drew up a new approach:
Now, my questions:
- will this work? I’ve not yet bought the ADS1115s so wanted an export opinion first
- the thermistors are 10Kohm but the tech sheet I found (for the Hayward solar controller - see below) provides measurements of resistance vs temperature using a 5V source - does this mean I should use 5V as well to have similar results? I know these are resistors and I think voltage doesn’t really matter but wanted to ask anyway. As the wires are quite long (ground to second-floor roof) perhaps 5V is better?
This is an extract of the Hayward resistance table:
Any advice anybody can give would be brilliant!
Thanks,
B.
